5 Replies Latest reply on Oct 1, 2014 1:33 AM by mraku
    Can't Open InDesign CC 2014
    LindaDininger Level 1
      Installed InDesign CC 2014.  Tried to open the program and received error:
      "Microsoft Visual C++ Runtime Library: Runtime Error!
      Program: C:\Program Files\Adobe\Adobe InDesign CC 2014\InDesign.exe
      This application has requested the Runtime to terminate it in an unusual way.
      Please contact the application's support team for more information."
        • 1. Re: Can't Open InDesign CC 2014
          Try rebooting. Also try logging in with a different user account on the computer. let us know if either works.
          • 2. Re: Can't Open InDesign CC 2014
            Already had tried both with no luck.
            • 3. Re: Can't Open InDesign CC 2014
              We don't know if you don't tell us.
              You should probably reinstall.
              • 4. Re: Can't Open InDesign CC 2014
                  I have uninstalled then reinstalled (twice).  I have uninstalled older versions of InDesign.  I have rebooted the system.  I have repeated all of those in different orders, just in case there was some magic in there.
                • 5. Re: Can't Open InDesign CC 2014
                  mraku
                  Given that you have had previous installations (like InDesign CS6) navigate to
                  C:\Users\[user]\AppData\Local\Adobe\InDesign\Version 10.0\en_GB\Caches
                  and try to remove the contents of InDesign Recovery folder except for the file called RecoveryData. I also deleted InDesign ClipboardScrap files.
                  Then I went to
                  C:\Users\[user]\AppData\Roaming\Adobe
                  and noticed, that I had "Adobe InDesign" folder that contained PREVIOUS installation (9.0) and "InDesign" folder with the current version (10.0). I deleted first folder (Adobe InDesign), renamed "InDesign" to "Adobe InDesign" went into it:
                  C:\Users\[user]\AppData\Roaming\Adobe\Adobe InDesign\Version 10.0\en_GB
                  and renamed InDesign Defaults (InDesign will recreate the file during opening, but you'll probably have to backup the workspace files.)
                  Then with the heart in my throat I launched InDesign and it f**king worked!!!
                  If that doesn't do for you mail me at michalkampa83@gmail.com because I recreated the procedure from memory so I could have forgotten something important! But I'm 99% sure it was all I did.
                  HOPE it works for all of you too!
