Installed CF 11 on Windows 7. Installed it using built-in server the first time and later using Apache server. I get the same results regardless of server installed.
The CFM page loads and displays text and will load <cfinclude> files. However a 404 error results when trying to load an .htm file. Also, in my .cfm index file, all CSS and Images are ignored (images show place holder box and Alt info but no image).
I attempted the above via DreamWeaver 8 and also by directly entering the URL into the browser. I have tested this with both Safari and FireFox. The examples below had their URLs entered directly (no DW involved).
The test pages I reference display perfectly in CF 9 but not in CF 11 (had same issue in CF10). I thought this was a TomCat problem at first. That is why I installed Apache.
The above is the CF 11 page (same results if built-in server or Apache).
This is the CF 9 page using built-in server.
This is the source for both instances (same exact file - not retyped)...
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>Untitled Document</title>
</head>
<body>
<img src="ContactHistory_400w.jpg" width="400" height="286" />
</body>
</html>
Notice: no ColdFusion code in the file. Does anyone have a solution? Thank you.
This may be caused by remnants of an old installation still on your machine. Delete all parts of a previous Coldfusion installation. At least, go to Windows Services and disable them. Restart Windows.
Run the Web Server Configuration Tool. Configure for Apache.
