4 Replies Latest reply on Jul 18, 2014 1:16 PM by MurraySummers
    DWCS6 - can't edit in Code view {subject edited by moderator}
    andybl
      In the split view or the design view, I can edit text anywhere on the page but when I click on the code side the text is grey and line number bar turns blue. Is there a way to turn the editing back on in the code view? Working on a PC with a document created on a mac.
        • 1. Re: In Dreamweaver CS6, I can't edit the code in file but I can edit in the design view or split view but only on the design side. I can't find how to enable editing in both views.
          Jon Fritz II Adobe Community Professional & MVP
          Are you working on a child page created from a DW Template file?
          Look in your source code, right in the beginning of the code, maybe line 2 or 3, you would see something like this...
          <!-- InstanceBegin template="/Templates/my_awesome_template.dwt" codeOutsideHTMLIsLocked="false" -->
          If that's there, you are working with a child page created from a DW .dwt Template file. If you are unable to change the code, it's because it is not within an editable region. The original .dwt would need to be changed, and the child updated, to unlock more areas for you to hand code in them.
          • 2. Re: DWCS6 - can't edit in Code view {subject edited by moderator}
            MurraySummers Level 8
            Can you still edit that gray text in Code view? Anyhow, paste your page's code into a reply here and we can tell you in a jiffy what's wrong (email won't work - you must post your code in the web forum).
            • 3. Re: DWCS6 - can't edit in Code view {subject edited by moderator}
              andybl Level 1
              No, it won't let me edit in the code at all.
              Here's the code:
              <!DOCTYPE HTML>
              <html><!-- InstanceBegin template="/Templates/OCVR.dwt" codeOutsideHTMLIsLocked="false" -->
              <head>
              <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
              <meta http-equiv="X-UA-Compatible" content="IE=edge" />
              <!-- InstanceBeginEditable name="doctitle" -->
                <title>OVCR | New Researcher Guide</title>
                <!-- InstanceEndEditable -->
              <!-- Mobile Specific Metas
              <meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, user-scalable=no">
              <!-- CSS
              <link rel="stylesheet" href="../css/reset.css" type="text/css" media="all" />
              <link rel="stylesheet" href="../css/responsive.css" type="text/css" media="all" />
              <!--[if lte IE 7]>
                <link rel="stylesheet" type="text/css" href="/ovcr/css/ie7.css" />
              <![endif]-->
              <!-- OTHER LINKS
              <link href="http://illinois.edu/lb/rss/19/text.xml" rel="alternate" type="application/rss+xml" title="Illinois News Bureau: Research" />
              <!-- JS
              <script src="http://ajax.googleapis.com/ajax/libs/jquery/1.8/jquery.min.js"></script>
              <script src="../scripts/search.js" type="text/javascript"></script>
              <script type="text/javascript" src="http://emergency.webservices.illinois.edu/illinois.js"></script>
              <!-- InstanceBeginEditable name="head" -->
                <link rel="stylesheet" href="../css/smoothness/jquery-ui-1.8.23.custom.css">
                <script src="http://ajax.googleapis.com/ajax/libs/jqueryui/1.8.23/jquery-ui.min.js"></script>
                <script>
                $(function() {
                $( "#accordion" ).accordion({
                active: false,
                autoHeight: false,
                collapsible: true,
                header: 'h2'
                </script>
              </head>
              <body>
              <div id="header">
                <div class="wrapper">
                <div id="logo"><a href="http://illinois.edu/"><img src="../images/uiuc.png" alt="The Office of the Vice Chancellor for Research" width="57" height="71" /></a><a href="../index.cfm"><img id="ovcr-logo" src="../images/invisible.png" alt="The Office of the Vice Chancellor for Research" width="437" height="63" /></a></div>
                <div id="campus">
                <ul id="nav_2">
                <li class="firstLI"><a href="http://illinois.edu/map/view">Maps</a></li>
                <li><a href="http://illinois.edu/ds/azList">A-Z Campus Index</a></li>
                </ul>
                <form action="" onSubmit="sendSearch()" id="" name="gs" method="get">
                <input type="hidden" name="search">
                <input type="hidden" value="all" name="search_type">
                <input type="hidden" value="" name="skinId">
                <input type="hidden" value="" name="cx">
                <input type="hidden" value="" name="cof">
                <input type="text" onFocus="checkSearchValue()" value="Search" size="10" class="searchbox" id="q" name="q">
                <input type="submit" id="go" class="searchbutton" value="Search" name="sa">
                <ul id="searchRadio">
                <li>
                <input type="radio" checked="checked" value="1" id="searchType_people" name="t">
                <label for="searchType_people">Directory</label>
                </li>
                <li>
                <input type="radio" value="2" id="searchType_info" name="t">
                <label for="searchType_info">Illinois</label>
                </li>
                </ul>
                </form>
                </div>
                </div>
              </div>
              <!-- <= end #header -->
              <div id="nav_main">
                <ul>
                <li><a href="../research/index.cfm">Research Funding</a></li>
                <li><a href="../policies/index.cfm">Policies &amp; Compliance</a></li>
                <li><a href="../training/index.cfm">Training for Researchers</a></li>
                <li><a href="index.cfm">About the OVCR</a></li>
                </ul>
              </div>
              <!-- <= end #navigation -->
                <div id="crumbs"><!-- InstanceBeginEditable name="crumbs" --><a href="../index.cfm">Home</a> &raquo; <a href="index.cfm">About the OVCR</a> &raquo; <strong>New Researcher Guide</strong><!-- InstanceEndEditable --></div>
                <!-- <= end #crumbs -->
                <div id="content-bg">
                <div id="content">
                <div id="article"> <!-- InstanceBeginEditable name="content" -->
                <div id="content">
                <div id="subNav"><!-- #BeginLibraryItem "/Templates/about.lbi" --><ul id="menu_resp">
                <li><a href="staff.cfm">Staff Directory</a></li>
                <li><a href="../orgchart.pdf">Organization Chart</a></li>
                <li><a href="committees.cfm">Committees of the VCR</a></li>
                <li><a href="units.cfm">Overview of Units</a></li>
                <li><a href="reports_statistics.cfm">Reports &amp; Statistics</a></li>
                <li><a href="Research_Admin_Guidelines.cfm">OVCR Research Administration Guidelines</a></li>
                <li><a href="volunteer.cfm">Volunteer to Help Illinois Research</a></li>
                <li><a href="contact.cfm">Contact Us</a></li>
              </ul>
              <p><a href="#" onClick="javascript:$('#menu_resp').slideToggle(); return false;" id="menu_m">&ndash; Menu &ndash;</a></p>
              <!-- #EndLibraryItem --></div>
                <div class="section">
                <h1>New Researcher Guide </h1>
                <div id="accordion">
                 <p><strong>Welcome to the Illinois Research Community!</strong></p>
                <p>Illinois is a large and complex institution, but we hope that you will soon find your way around both the physical and the electronic campus.<br>
                 <br>
                 Our culture values collegiality and interdisciplinary research, and we hope this page provides the basic information you need to help you launch your own productive research endeavors.<br>
                <br>
                         Click on the tabs below for select links and information about the Illinois research community. More detailed information can be found throughout this website - and if you need additional guidance, don't hesitate to <a href="mailto:OVCR@illinois.edu">contact us</a>. </p>
              <h2><a href="#">Find Research Resources</a></h2>
                 <div>
                <p>Your college's research office can provide specifics, as individual research needs will vary depending upon your discipline, but the following links may help you find the tools, equipment, and services to achieve your research goals: </p>
                <p><a href="http://research.illinois.edu/units/technology.cfm">Campus research facilities and services</a><a href="http://research.illinois.edu/about/programs-and-resources.cfm"><br>
                   Research programs and additional resources</a></p>
                <p>Select items that may be of particular interest to new faculty include:</p>
                 <p><a href="http://www.library.illinois.edu/sc">Library research resources (Scholarly Commons) </a><br>
                   <a href="http://www.library.illinois.edu/ugl/mc/">Support for producing digital media  (Media Commons)</a><a href="https://ideals.illinois.edu/"> <br>Research Repository (IDEALS)</a><a href="http://itg.beckman.illinois.edu/visualization_laboratory/"><br>
                     Modeling, imaging, and graphic design services (Beckman Vis Lab) and</a><a href="http://www.igb.illinois.edu/core">Microscopy services (IGB Core Facilities)</a><a href="http://www.it.illinois.edu/"><br>
                     Computing resources (IT Excellence)</a></p>
                         </div>
                <h2><a href="#">Find Funding</a></h2>
                 <div>
                <p> Your departmental business office can  guide you, but when you are ready to look for funding, the OVCR can help.</p>
                <h4>Internal Funding Resources:</h4>
                                      <p>The <a href="http://crb.research.illinois.edu/">Research Board</a> provides support for new faculty to initiate research at Illinois. <a href="http://research.illinois.edu/research/Funding_Opportunities.cfm"><br>
                                      Additional Campus Funding Opportunities</a></p>
                                      <h4>External Funding Resources:</h4>
                                      <p><a href="http://externalfunding.research.illinois.edu/Default.aspx">Limited Submissions</a><a href="https://www.grantforward.com/index"><br>
                                        Grant Forward </a></p>
                                      <p>The OVCR offers <a href="http://research.illinois.edu/research/support.cfm">additional support</a> to faculty in the humanities, arts, and social sciences<em>. </em></p>
                                      <p><em><br />
                                      </em> </p>
                                    </div>
                <h2><a href="#">Hire Staff</a><br />
                </h2>
                <div>
                <p>Your departmental business office should be able to assist you with personnel needs. There are many different employee classifications, and the hiring process differs significantly depending on the position.</p>
                <p>Visit the Illinois Human Resources <a href="http://humanresources.illinois.edu/index.html">website</a> for more information. <br />
                 </p>
                   </div>
                <h2><a href="#">Find Collaborators</a></h2>
                <div>
                <p>The University of Illinois at Urbana-Champaign is currently developing a &quot;Faculty Experts Database&quot;<em> -</em> a tool that will showcase faculty expertise and help you to connect with colleagues. We will launch that service in Fall 2013, but in the meantime we encourage you to connect with your department head and senior faculty, and your college's senior administration. They can provide suggestions on connecting with other researchers across campus. </p>
                <p>Additionally, the research   institutes that report to the OVCR are hubs of collaboration and interdisciplinary research on campus: </p>
                <p><a href="http://beckman.illinois.edu/">Beckman Institute for Advanced Science and Technology</a></p>
                <p><a href="http://www.igb.illinois.edu">Institute for Genomic Biology</a></p>
                <p><a href="http://www.ncsa.illinois.edu/">National Center for Supercomputing Applications</a></p>
                <p><a href="http://www.prairie.illinois.edu/">Prairie Research Institute</a><br />
                 </p>
                                      </div>
                <h2><a href="#">Understand Regulatory Requirements</a></h2>
                <div>
                <p>Supporting the   safe and ethical conduct of research is a priority for the Office of the Vice Chancellor for Research at the University of Illinois at Urbana-Champaign. Review a <a href="http://research.illinois.edu/policies/checklist.cfm">checklist</a> to help you get started, or learn more about research <a href="http://research.illinois.edu/policies/index.cfm">policies</a>and required<a href="http://research.illinois.edu/training/index.cfm"> training.</a><em><br />
                 </em> </p>
                </div>
                                      <h2><a href="#">Share Your Results</a></h2>
                <div>
                <p>The<a href="http://otm.illinois.edu/"> Office of Technology Management</a> can help you understand the intellectual property issues in research activities and your role in commercializing university innovation. </p>
                <p>The  News Bureau generates and coordinates national news coverage of the Urbana-Champaign campus. News Bureau writers cover <a href="http://news.illinois.edu/about_staff.html">specific campus beats</a> and also provide advice for interacting with the media. </p>
                <p>Many departments and colleges also have communications staff to help share news and research results. Find your unit's &quot;Chief Communications Officer&quot; <a href="http://publicaffairs.illinois.edu/campus/cco.html">here</a>. <em><br />
                 </em></p>
                       </div>
                <h2><a href="#">People in Research: The Names You Need to Know</a></h2>
                                          <div>
                <h4><a href="../orgchart.pdf">OVCR Org Chart</a> </h4>
                <p><a href="http://research.illinois.edu/about/staff.cfm"><br>
                   Office of the Vice Chancellor for Research</a><br>
                 Peter Schiffer, Vice Chancellor for Research<br>
                 Melanie Loots, Executive Associate Vice Chancellor for Research<br>
                 Jan Novakofski, Associate Vice Chancellor, Compliance<br>
                 Nancy Abelmann, Associate Vice Chancellor for Humanities, Arts, and Related Fields
                                            <br>
                                            Howard Guenther, Associate Vice Chancellor, Research Integrity Officer
                </p>
                <p><a href="http://www.ospra.illinois.edu/">Office of Sponsored Programs</a><br>
                 Dave Richardson, Director </p>
                <p><a href="http://irb.illinois.edu/">Institutional Review Board</a><br>
                 Anita Balgopal, Director</p>
                <p> <a href="http://www.drs.illinois.edu/">Division of Research Safety</a><br>
                 Peter Ashbrook, Director</p>
                <p><a href="http://dar.research.illinois.edu/">Division of Animal Resources</a><br>
                 Lyndon Goodly, Director</p>
                <p><a href="http://biomedical.illinois.edu/">Division of Biomedical Sciences</a><br>
                 Jennifer Eardley, Interim Director
                </p>
                                          </div>
                <p> </p>
                   </div>
                <!-- <= end .section -->
                <div class="clear"></div>
                <!-- InstanceEndEditable --> </div>
                </div>
                </div>
                <!-- <= end #content --></div>
              <div id="footer">
                <div id="address">
                <p><strong>Office of the Vice Chancellor for Research</strong><br>
                Fourth Floor, Swanlund Administration Building, MC-304<br>
                601 E. John Street, Champaign, IL 61820</p>
                </div>
                <div id="email">
                <p><strong>Email:</strong> <a href="mailto:OVCR@illinois.edu">OVCR@illinois.edu</a><br>
                <strong>Phone:</strong> 217-333-0034<br>
                <strong>Fax:</strong> 217-244-3716</p>
                </div>
                <p id="c">&copy; 2012 Board of Trustees of the <a href="http://illinois.edu/">University of Illinois</a></p>
                </div>
              </div>
              <!-- <= end #footer --> <script src="../scripts/menu.js"></script> <script type="text/javascript" src="http://emergency.webservices.illinois.edu/illinois.js"></script>
              <!-- InstanceBeginEditable name="footer" --><!-- InstanceEndEditable -->
              <div id="modal"></div>
              var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");
              document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"));
              </script>
              try {
              var pageTracker = _gat._getTracker("UA-6127625-1");
              pageTracker._trackPageview();
              } catch(err) {}
              </script>
              </body>
              <!-- InstanceEnd --></html>
              • 4. Re: DWCS6 - can't edit in Code view {subject edited by moderator}
                As Jon suggested, this page is definitely the child page of a Dreamweaver template -
                You must edit the template to do one of two things:
                1. Change code in a way that appears on *all* child pages, or
                2. Change the template so that all child pages are editable in the region where you want to make the changes
                If you don't understand these two alternatives, you should read and understand DW's F1 Help about creating and using Templates on your site before you do anything else. They are NOT intuitive.
