1 Reply Latest reply on Jul 18, 2014 2:51 PM by A.T. Romano
    Can I process a video that has 50fps @ 300% to 30fps?
    terrence.a.foster
      Hey all,
      I need HELP. I have a video editing project for work and my system isn't working.
      I have Adobe Premiere Elements 12.
      I have a video that is 50fps. I need to speed it up to 300% and then export it as a HDTV 1080p 29.97fps .mgp.
      Is this possible? What tips or tricks do you have to make this easier on me?
      Thank you SO. MUCH.
      ~T
        • 1. Re: Can I process a video that has 50fps @ 300% to 30fps?
          A.T. Romano Level 7
          terrence.a.foster
          I will assume for now that your Premiere Elements 12 is on Windows 7, 8, or 8.1 64 bit.
          (As an aside, please update from 12 to 12.1 via a project's Help Menu/Update.
          Have you worked through the following to your goal....
          Project Preset = PAL AVCHD AVCHD 1080p50
          Import your file into the Expert workspace, Add Media/Files and Folders/Project Assets.
          From Project Assets drag your file to the Timeline Video Track 1.
          Right click the file there, select Time Stretch and set the Speed % = 300. Render the Timeline content by pressing the Enter key of the computer main keyboard or the Render button above the Timeline.
          Export Publish+Share/Computer/MPEG with preset = HDTV 1080p25 High Quality.
          I was not sure what to make of your "HDTV 1080p 29.97fps .mgp"
          Since your source has a typically PAL frame rate 50 progressive frames per second, not sure why you would we using the typically NTSC frame rate 29.97 progressive frames per second instead of PAL's 25. I guessed that mgp was a typing error, and that you mean to type mpeg, indicating the Publish+Share/Computer/MPEG export path.
          You could also look at Tool Menu/Time Remapping for the 300% Fast Motion effect (See setting between Forward/Fast 2X and Very Fast 4X).
          Please review and clarify and let us know if the above works for you.
          Thank you.
          ATR
