6 Replies Latest reply on Apr 30, 2007 2:38 AM by goransv
    Enumeration problem consuming clickandbuy web service
    goransv
      I have built a cf app that will consume Click & Buy´s SOAP interface RMI (Registration Manager Interface) to register new Users. Click & buy states that the SOAP interface is 1.2 compliant, but my test with different generic soap client indicates that it is not true.
      Any way I have managed to do all the structs and arrays, but get stuck on a enumerated value. I got this error:
      Could not perform web service invocation "registerUser".
      Here is the fault returned when invoking the web service operation:
      java.lang.IllegalArgumentException: argument type mismatch
      I have read all the documentation for the RMI, so I know the right values. But I do not know how to set a value to type enumerated. I have installed all the lates hotfixes (CFMX 7.02, win 20003), tested to consume other web services like babelfish and a weather service with no problem. I have also googled and read all threads on the subject, and that there was a fix for this problem in the work back in 2005. I think that by now there should be a fix for the enum problem so that you don´t have to use bad temporay solutions, but I have found nothing!
      I have also run the web service with wsdl2java and examined the classes with Eclipse. I´m no Java programer but I think I have manged to pin point the origin of the error message in the RegistrationManagerRegistrationGender class.
      It feels as I am stuck on the finish line.
      References:
      http://mail-archives.apache.org/mod_mbox/ws-axis-dev/200604.mbox/%3C4736124.1145204669658. JavaMail.jira@brutus%3E
      http://www.houseoffusion.com/groups/cf-talk/thread.cfm/threadid:30232
      http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=1&catid=7&threadid=12 51325&highlight_key=y&keyw
      ord1=enum
      http://www.sys-con.tv/read/86131.htm
      http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=kb400996
      http://www.xmethods.net/ve2/Tools.po
      http://www.mindreef.net/tide/scopeit/start.do
      http://wsdl.eu.clickandbuy.com/RMI/2.0/RegistrationManagerbinding.wsdl
      http://soapclient.com/interop/interopTest.html
      http://soapclient.com/soapclient.com/soaptest.html
