3 Replies Latest reply on Jul 19, 2014 6:22 PM by Johnwhite
    Script UI layout
    Johnwhite Level 1
      Hi everyone,
      I made a Script UI like this:
      the code:
      var myDialog = app.dialogs.add({name:"Modify current years' cells"});
      with(myDialog.dialogColumns.add()){
        with(dialogRows.add()){
         with(dialogColumns.add()){
          with(borderPanels.add()){
           staticTexts.add({staticLabel:"Column fill colour?"});
           var myVerticalAlignmentButtons = radiobuttonGroups.add();
           with(myVerticalAlignmentButtons){
            radiobuttonControls.add({staticLabel:"Yes", checkedState: true});
            radiobuttonControls.add({staticLabel:"No"});
         staticTexts.add({staticLabel:"Color:"});
                 var mySelection = dropdowns.add({stringList:["Red", "Green"], selectedIndex:1});
         staticTexts.add({staticLabel:"Tint:"});
                 var mySelection = dropdowns.add({stringList:["10%", "15%", "20%", "25%", "30%"], selectedIndex:2});
           staticTexts.add({staticLabel:"With stroke?"});
         staticTexts.add({staticLabel:"Stroke colour:"});
         staticTexts.add({staticLabel:"Stroke weight:"});
                 var mySelection = dropdowns.add({stringList:["0.5pt", "1pt", "1.5pt", "2pt"], selectedIndex:1});
         staticTexts.add({staticLabel:"In which row:"});
                 var mySelection = dropdowns.add({stringList:["1st", "2nd", "3rd", "4th", "5th", "th"], selectedIndex:1});
      myDialog.show();
      but I want this layout,
      Can someone help me to reorder it?
      John
        • 1. Re: Script UI layout
          Johnwhite wrote:
          [.. stuff.. ]
          No.
          This is not "Script UI", it is the older basic interface. You can only influence the order in a very general way (by carefully dividing your dialog into rows and columns, and adding them one at a time. The specific "alignment" of each of your parts with respect to each other is not possible).
          To mimic your design, you are better off with the real Script UI.
          • 2. Re: Script UI layout
            Johnwhite Level 1
            Hi, Jongware
            but finally I want change it to script UI, so I design the interface first.
            Is that feasible?
            John
            • 3. Re: Script UI layout
              Johnwhite Level 1
              Hi, Jongware
              I change it into this:
                 staticTexts.add({staticLabel:"Tint:   "});
                         var mySelection = dropdowns.add({stringList:["0.5pt", "1pt", "1.5pt", "2pt"], selectedIndex:2});
                   staticTexts.add({staticLabel:"Dollar sign Italic?"});
                         var mySelection = dropdowns.add({stringList:["1st", "2nd", "3rd", "4th", "5th", "6th"], selectedIndex:1});
                    myDialog.show();
              but the outcome like this:
              no what I want
              How can I move second and third cloumn under the first?
              John
