2 Replies Latest reply on Jul 19, 2014 12:25 PM by DavePinMinn
    How do I update label names in images?
    DavePinMinn Level 1
      Over time, I've changed the way I use the star ratings and the labels.
      So, if I have an image with a green label that's named X and I change the green label to be Y, HOW do I get the image to have Y and a green label instead of X and a white label?
      I can't find a method in the search that looks at the label text in the image, so how do I find all the images with "X" so I can change them to "Y"?
        • 1. Re: How do I update label names in images?
          RikkFlohr Adobe Community Professional
          In your Catalog panel, select All Photographs
          Go to Library and select Grid view.
          Hit the [ \ ] key to activate the Library Filter
          Change the first column to be Label
          In the Labels that appear underneath click on the one you want to change
          [Ctrl/Cmd][ A ] to select all
          In the Metadata Panel on the RH side change the text in the Label field
          • 2. Re: How do I update label names in images?
            DavePinMinn Level 1
            Thanks Rikk..........
            Internal groans and laughter here!  That's exactly WHAT I UNDID!!!!!!!!!!  I activated the library filter, and on the "Label" pane, I replaced label with Metadata status (never even LOOKED at the label data) - which didn't work, then opened text and tried putting in the label names, which didn't work, then I did a search through all the menu pulldowns, then an Internet search....  Had I actually LOOKED at the data in "label", I'd have saved myself a lot of fiddling and a bit of embarrassment!
            Off to change a LOT of labels!
