6 Replies Latest reply on Jul 20, 2014 5:08 PM by Noel Carboni
    using clone tool makes screen go black?
    wildlifesnapper
      i have just started using the cloud photoshop version
      i have just tried using the clone tool and after i selected the area with alt+click - when i try and to close over an area the screen keeps going black?
      does anyone know why? thanks
        • 1. Re: using clone tool makes screen go black?
          Use Photoshop menu Help>System Info.. and use its copy button and paste your info in here.  You most likely have an old display driver installed and need to install and updated one.
          • 2. Re: using clone tool makes screen go black?
            Noel Carboni Level 8
            +1 to JJ's comment.  It's a known thing with Windows 8 and early releases of display drivers.
            -Noel
            • 3. Re: using clone tool makes screen go black?
              wildlifesnapper Level 1
              hi, thanks for the help it says the below (there was a lot of text!!) this is the top bit, is this enough to tell?
              Adobe Photoshop Version: 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00) x32
              Operating System: Windows 8 64-bit
              Version: 6.2
              System architecture: Intel CPU Family:6, Model:10, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
              Physical processor count: 4
              Logical processor count: 8
              Processor speed: 2395 MHz
              Built-in memory: 8083 MB
              Free memory: 6139 MB
              Memory available to Photoshop: 3255 MB
              Memory used by Photoshop: 60 %
              Image tile size: 128K
              Image cache levels: 4
              Font Preview: Medium
              TextComposer: Latin
              Display: 1
              Display Bounds: top=0, left=0, bottom=900, right=1600
              OpenGL Drawing: Enabled.
              OpenGL Allow Old GPUs: Not Detected.
              OpenGL Drawing Mode: Advanced
              OpenGL Allow Normal Mode: True.
              OpenGL Allow Advanced Mode: True.
              AIFCoreInitialized=1
              AIFOGLInitialized=1
              OGLContextCreated=1
              NumGPUs=1
              gpu[0].OGLVersion="3.0"
              gpu[0].MemoryMB=2112
              gpu[0].RectTextureSize=8192
              gpu[0].Renderer="Intel(R) HD Graphics 4000"
              gpu[0].RendererID=358
              gpu[0].Vendor="Intel"
              gpu[0].VendorID=32902
              gpu[0].HasNPOTSupport=1
              gpu[0].DriverVersion="8.982.6.0"
              gpu[0].Driver="igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32"
              gpu[0].DriverDate="20120801000000.000000-000"
              gpu[0].CompileProgramGLSL=1
              gpu[0].TestFrameBuffer=1
              gpu[0].OCLPresent=0
              gpu[0].CUDASupported=0
              gpu[0].OCLBandwidth=0
              gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 9.17.10.2817"
              gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447]
              gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
              gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[80]
              gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
              gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
              gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
              gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[1024]
              gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[1024]
              gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
              gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
              gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
              gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
              gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
              gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
              gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
              gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
              gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
              gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
              gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
              gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
              License Type: Subscription
              • 4. Re: using clone tool makes screen go black?
                Those were the important parts.
                Your driver is 2 years out of date.  I suggest visiting Intel.com and seeing if you can get a current display driver release for your hardware and OS.
                -Noel
                • 5. Re: using clone tool makes screen go black?
                  Noel,
                  hi thank you very much for your help with this
                  i went to the intel site and did their auto checker and it gave the below results, so im guessing this means i now have to contact samsung directly? - to see if they have one of their own drivers?
                  thanks emma
                  Graphics Driver
                  Product DetectedIntel® HD Graphics 4000
                  Current Driver Installed8.982.6.0
                  A customized computer manufacturer driver is installed on your computer. The Intel Driver Update Utility is not able to update the driver. Installing a generic Intel driver instead of the customized computer manufacturer driver may cause technical issues. Contact yourcomputer manufacturer for the latest driver for your computer.
                  Intel Chipset Software Installation Utility (Chipset INF)
                  Audio Driver for Intel Desktop Board
                  Product DetectedRealtek High Definition Audio
                  Current Driver Installed6.0.1.6702
                  This device is unknown or unsupported. Please contact the manufacturer for possible updates. More information>>
                  Wireless Networking (WiFi)
                  Product DetectedQualcomm Atheros AR9485WB-EG Wireless Network Adapter
                  Current Driver Installed10.0.0.75
                  Wired Networking
                  Product DetectedRealtek PCIe GBE Family Controller #2
                  Current Driver Installed8.2.612.2012
                  • 6. Re: using clone tool makes screen go black?
                    Checking first with the computer maker is the best idea, but they sometimes don't update older systems.
                    In a pinch I see that the language above from Intel says that installation of their driver MAY cause technical issues.
                    -Noel
