2 Replies Latest reply on Apr 30, 2007 11:14 AM by Andrew Pitts
    String.split(',') function to numeric array.
    Andrew Pitts
      I'm a newbie to Actionscript but have been coding Coldfusion for years.
      In my database tables I frequently use a string field to contain small lists of integer key values. This came about by Coldfusion's great List functions for handling this type of data.
      I'm trying to duplicate some of these list functions in Actionscript. Most useful to me is the ListFind() which takes a ListString and searches for a particular integer value.
      In actionscript I've coded it as follows:
      var stringList:String = '10,11,15,24';
      var testInt:Int = 15;
      var listArray:Array = stringList.split(',');
      if ( listArray.indexOf( testInt.toString() ) > -1 )
      then in list;
      else
      not in list;
      While this works fine, I was still wondering if there was a way in which I could cast the array elements returned by the split function so that they would be integer values instead of string values. This would allow me to remove the .toString() necessary in the indexOf() function.
