7 Replies Latest reply on Jul 23, 2014 6:45 AM by Teetan VK
    Paste in place to next Master unfunction, can you fix it?
    Teetan VK Level 1
      Hi, everyone
      I got this script, which copy from:
      Paste In Place to Specify Master Page
      I change it into:
      var myDialog = app.dialogs.add({name:"Copy Select item to next Master",canCancel:true});
      with(myDialog){
          with(dialogColumns.add()){
          staticTexts.add({staticLabel:"Select a Master you want to copy to"});
              with(dialogRows.add()){
                 var mySelection = dropdowns.add({stringList:["Master A", "Master B","Master C", "Master D", "Master E","Master F", "Master G"], selectedIndex:0});
      if (myDialog.show() == true)
      function main(){
        if("Copy to next Master");
            copy_to_next_master();
      function copy_to_next_master() {
          if (mySelection.selectedIndex == 0){
      var nSel = app.selection.length;
      for ( var i = 1; i < app.documents.length; i++) {
              var nextDoc = app.documents[i];
              if (!nSel) { alert( "Nothing selected!" ); exit(); }
              for ( var n = 0; n < nSel; n++ ) {
                  var curSel = app.selection[n];
                  curSel.duplicate( nextDoc.masterSpreads[0] );
      alert("Done.\rWhat you select are pasted in place to next documents' Master  A");
          if (mySelection.selectedIndex == 1){
                  curSel.duplicate( nextDoc.masterSpreads[1] );
      alert("Done.\rWhat you select are pasted in place to next documents' Master  B");
                  curSel.duplicate( nextDoc.masterSpreads[2] );
      alert("Done.\rWhat you select are pasted in place to next documents' Master  C");
                  curSel.duplicate( nextDoc.masterSpreads[3] );
      alert("Done.\rWhat you select are pasted in place to next documents' Master  D");
                  curSel.duplicate( nextDoc.masterSpreads[4] );
      alert("Done.\rWhat you select are pasted in place to next documents' Master  E");
                  curSel.duplicate( nextDoc.masterSpreads[5] );
      alert("Done.\rWhat you select are pasted in place to next documents' Master  F");
                  curSel.duplicate( nextDoc.masterSpreads[6] );
      alert("Done.\rWhat you select are pasted in place to next documents' Master G");
      but unfunction, can you fix it?
      thanks
      Teetan
        • 1. Re: Paste in place to next Master unfunction, can you fix it?
          Chinnadk Level 4
          Hi Teetan
          Try this, it will ask you to select a master of the current document, if any of the other opened document master page name matches with the selected master name, then it will copy all the elements from selected master to the other opened documents master page.
          var doc =app.activeDocument,
              masters = doc.masterSpreads,
              masternames = [],
              with(myDialog)
                          for(var i=0;i<masters.length;i++)
                                  masternames.push(masters[i].name);
                          var mySelection = dropdowns.add({stringList:masternames, selectedIndex:0});
              myDialog.show();
          var selectedmaster = mySelection.stringList[mySelection.selectedIndex],
              allItems = doc.masterSpreads.item(selectedmaster).pageItems;
          for(var i =1;i<app.documents.length;i++)
                  for(var j=0;j<allItems.length;j++)
                          allItems[j].duplicate(app.documents[i].masterSpreads.item(selectedmaster))
          Regards,
          Chinna
          • 2. Re: Paste in place to next Master unfunction, can you fix it?
            Teetan VK Level 1
            Hi, Chinna
            thank you for your help,
            but the script only can paste in place to next master A, not work in B,C,D....
            why?
            Regard
            VK
            • 3. Re: Re: Paste in place to next Master unfunction, can you fix it?
              Chinnadk Level 4
              Try now.
                  masternames = [],
                  with(myDialog)
                  myDialog.show();
                      for(var k =0;k<app.documents[i].masterSpreads.length;k++)
                                  allItems[j].duplicate(app.documents[i].masterSpreads[k])
              Regards,
              Chinna
              • 4. Re: Paste in place to next Master unfunction, can you fix it?
                Teetan VK Level 1
                Hi, Chinna
                I try it three times
                but still not working
                vk
                • 5. Re: Re: Paste in place to next Master unfunction, can you fix it?
                  Jump_Over Level 5
                  Modifying your code - notice that function main() suppose to be
                  1. defined and
                  2. called
                  Compare it to this code:
                  #target  indesign
                  var
                    myDialog = app.dialogs.add({name:"Copy Selected item(s) to chosen Master",canCancel:true}),
                    mStringList = ["Master A", "Master B","Master C", "Master D", "Master E","Master F", "Master G"];
                  with(myDialog){
                    var mySelection = dropdowns.add({stringList:mStringList, selectedIndex:0});
                  main();
                  function main(){
                    if (!app.documents.length || !app.selection.length)
                    exit();
                  var
                    mChoice = mySelection.selectedIndex,
                    mMsg = "Done.\rWhat you select is pasted in place to next documents - " + mStringList[mChoice],
                    nSel = app.selection.length,
                    mDone = false,
                    i,n,nextDoc,curSel;
                  for ( i = 1; i < app.documents.length; i++) {
                    targetMaster = nextDoc.masterSpreads[mChoice];
                    if (!targetMaster.isValid) {
                    mMsg += "\rCan't detect " + mStringList[mChoice] + " in a doc: " + nextDoc.name;
                    continue;
                    mDone = true;
                    for ( n = 0; n < nSel; n++ ) {
                    curSel.duplicate( nextDoc.masterSpreads[mChoice] );
                  mDone ? alert(mMsg) : alert("Nothing copied");
                  Jarek
                  • 6. Re: Paste in place to next Master unfunction, can you fix it?
                    Teetan VK Level 1
                    Thank you Jarek
                    I think I have learn how to call function in Java
                    thank so much
                    regard
                    VK
                    • 7. Re: Paste in place to next Master unfunction, can you fix it?
                      Teetan VK Level 1
                      Hi, Chinna
                      Thank you for your help, appreciate.
                      I finally get What I want.
                      But I still remain another script need fix it, do you have anything idea to fix?
                      How can use radiobuttonControls to join three scripts together?
                      as same as this script, I want joint the script together, but I don't know how to call function
                      thanks
                      Regard
                      VK
