4 Replies Latest reply on Jul 21, 2014 2:53 PM by A.T. Romano
    when i open premiere elements 12 error 1
    boymarine Level 1
      when tech down loaded adobe elements premiere 12 error 1
        • 1. Re: when i open premiere elements 12 error 1
          Jeff A Wright Adobe Employee
          Boymarine do you receive error 1 when opening or installing Adobe Premiere Elements?  Also which operating system are you using?
          • 2. Re: when i open premiere elements 12 error 1
            boymarine Level 1
            windows 8.1 and after it is installed and when I try to open
            • 3. Re: when i open premiere elements 12 error 1
              Moving this discussion to the Premiere Elements forum.
              • 4. Re: when i open premiere elements 12 error 1
                A.T. Romano Level 7
                boymarine
                Who installed this program for you - Adobe Tech or other?
                If Adobe Tech, then please contact it via Adobe Chat or whatever contact information that you have for it in order to sort out the
                details of "Downloading, Installing, and Setting Up"
                Contact Customer Care
                Going that route may get you some remote control troubleshooting which is not available at this user to user forum.
                Does your computer meet Premiere Elements 12 System Requirements?
                Does the problem exist if you have the antivirus program disabled?
                Do you have the latest version of QuickTIme installed?
                Are you using a User Account with Administrative Privileges and working from application of Run As Administrator to
                the Premiere Elements 12 desktop icon?
                Is your video card/graphics card up to date according to the web site of the manufacturer of the card?
                You can try to delete the Adobe Premiere Elements Prefs file and, if necessary, the whole 12.0 Folder in which it exists.
                Local Disk C
                Users
                Owner
                AppData
                Roaming
                Adobe
                Premiere Elements
                12.0
                and in the 12.0 Folder is the Adobe Premiere Elements Prefs file that you delete. If that does not work, then delete the whole
                12.0 Folder in which the Adobe Premiere Elements Prefs file exists. Be sure to be working with Folder Option Show Hidden
                Files, Folders, and Drives active so that you can see the complete path.
                If none of that works, then it is time for a program deactivation if you can get into the program (Help Menu/Sign Out)..skip if you cannot
                open a project, uninstall (control panel route), free ccleaner run through (regular cleaner and registry cleaner parts), reinstall with
                antivirus and firewall(s) disabled.
                CCleaner - PC Optimization and Cleaning - Free Download
                Please review and consider. We will be watching for your progress.
                Thank you.
                ATR
