3 Replies Latest reply: Jul 25, 2014 3:13 PM by zambonee RSS
    Get the number of CountItems by group in CS5 extended
    zambonee Community Member
      I have a collection of photos with count items created with the Count Tool in CS5 extended version. Each count item belongs to one of 5 count groups created with the Count Tool. Using the Photoshop COM, I can get the total number of count items per photo (Document.CountItems.Count()). However, I cannot get the number of count items per count group, or the group a count item belongs to. Has anybody had success in accessing count groups? I am using C#, but a solution in any language would be helpful.
        • 1. Re: Get the number of CountItems by group in CS5 extended
          Muppet Mark Community Member
          Hum the counters is an odd thing… It looks like it does all or nothing…?
          If I change group visibility it does NOT change the count unless I do it to ALL…?
          if any 1 group is visible the the count length is ALL…?
          So using Adobe extendScript I can do this as alt…?
          #target Photoshop
          var doc = app.activeDocument;
          for ( var i = 4; i >= 0; i-- ) { // Just a reverse remove
            var allCounts = doc.countItems.length;
            alert( ' All remaining Counters: ' + allCounts ); // All the doc counts…
            selectCountGroup( i );
            clearCountGroup();
            var newCount = doc.countItems.length;
            var grpCount = allCounts - newCount;
            alert( 'Group ' + ( i + 1 ) + ' Counters: ' + grpCount )
          // This has NO affect on count its either ALL || NOTHING
          function countGroupVisible() {
            function cTID(s) { return app.charIDToTypeID(s); };
            function sTID(s) { return app.stringIDToTypeID(s); };
              var desc130 = new ActionDescriptor();
              desc130.putBoolean( cTID('Vsbl'), false );
              executeAction( sTID('countGroupVisible'), desc130, DialogModes.NO );
          function selectCountGroup( numb ) {
              var desc133 = new ActionDescriptor();
              desc133.putInteger( cTID('ItmI'), numb );
              executeAction( sTID('countSetCurrentGroup'), desc133, DialogModes.NO );
          function clearCountGroup() {
              var desc198 = new ActionDescriptor();
              executeAction( sTID('countClear'), desc198, DialogModes.NO );
          • 2. Re: Get the number of CountItems by group in CS5 extended
            cbuliarca Community Member
            Hi here are some functions on how to get the length of the counts for one group:
            // examples:===================
            alert("there are "+getCountsInGroup(getCurrentGroup()).length+ " counts in the selected countGroup");// getting the counts for the current selected group
            //getCountsInGroup(0);//get counts for the first group
            function getCountsInGroup( idx ){
              var cArr = listCountsArr();
              return cArr[idx];
            function getCurrentGroup(){// find the index of the selected group
              var firstArr = listCountsArr();// make a list with arrays as grpoups and inside them objects for each count
              addTempCount();// create a temp cont
              var secArr = listCountsArr();// make a second list
              theCGroup = 0;
              for( i=0; i<firstArr.length; i++){// compare the listCountsArr
              if( firstArr[i].length != secArr[i].length){
              theCGroup = i;
              break;
              deleteCount( secArr[theCGroup][secArr[theCGroup].length - 1].idx + 1);// detele the temp count
              return theCGroup;
            function addTempCount(){
              var desc = new ActionDescriptor();
                 desc.putDouble( charIDToTypeID( "X   " ), 0 );
                 desc.putDouble( charIDToTypeID( "Y   " ), 0 );
              executeAction( stringIDToTypeID( "countAdd" ), desc, DialogModes.NO );
            function deleteCount( idx ){
                 desc.putInteger( charIDToTypeID( "ItmI" ), idx );
              executeAction( stringIDToTypeID( "countDelete" ), desc, DialogModes.NO );
            function listCountsArr(){
              var cArr = new Array();
              var ref = new ActionReference();
               ref.putEnumerated( charIDToTypeID("Dcmn") , charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
               desc1 = executeActionGet(ref);
               desc1 = desc1.getList(stringIDToTypeID('countClass'));
               var crntG = 0;
               var grpArr = new Array();
               for(var i = 0; i<desc1.count; i++){
                var gr = desc1.getObjectValue(i).getInteger(charIDToTypeID("Grup"));
                var itI = desc1.getObjectValue(i).getInteger(charIDToTypeID("ItmI"));
                var itX = desc1.getObjectValue(i).getUnitDoubleValue(charIDToTypeID("X   "));
                var itY = desc1.getObjectValue(i).getUnitDoubleValue(charIDToTypeID("Y   "));
                var cntObj = {idx:itI, x:itX, y:itY, grpIDX:gr, domI: i};
                if(crntG == gr ){
                grpArr.push(cntObj);
                if(crntG != gr ){
                cArr.push(grpArr);
              crntG = gr;
               cArr.push(grpArr);
               return cArr;
            • 3. Re: Get the number of CountItems by group in CS5 extended
              Muppet Mark's and cbuliarca's both worked- thanks for your replies! For the record, I ended up using this in C#:
              ps.ApplicationClass app = new Photoshop.ApplicationClass();
                                  app.Visible = false;
                                  ps.Document doc = app.Open(str, null, false);
                                  app.ActiveDocument = doc;
                                  var Ref = new ps.ActionReference();
                                  Ref.PutEnumerated(app.CharIDToTypeID("Dcmn"), app.CharIDToTypeID("Ordn"), app.CharIDToTypeID("Trgt"));
                                  var desc1 = app.ExecuteActionGet(Ref);
                                  var desc2 = desc1.GetList(app.StringIDToTypeID("countClass"));
                                  int[] arrCounts = new int[5] { 0, 0, 0, 0, 0};
                                  for (int i = 0; i < desc2.Count; i++)
                                      int gr = desc2.GetObjectValue(i).GetInteger(app.CharIDToTypeID("Grup"));
                                      arrCounts[gr] = arrCounts[gr] + 1;
