2 Replies Latest reply on Jul 2, 2007 8:21 AM by Newsgroup_User
    Any SQL geniuses out there?
    Level 7
      I am attempting to fix a SQL error that was given to me a little outside of
      my experience. Its a CASE statement that is trying to concatenate to a
      string if the conditions are met, but I am getting this error:
      Cannot use empty object or column names. Use a single space if necessary.
      This is the code. Any glaring error?
      case
      when academic.expect_grad_mm<>''
      and academic.expect_grad_yyyy<>''
      then academic.expect_grad_mm+'/31/'+academic.expect_grad_yyyy
      else ""
      end
      All the columns are there and this supposedly worked a couple months ago.
        • 1. Re: Any SQL geniuses out there?
          Level 7
          > case
          > else ""
          > end
          > Thanks
          A bit of a guess here, but this is what caught my eye.
          'Cannot use empty object or column names. Use a single space if necessary.'
          AND
          'else ""'
          I would hazard a guess that you need to return something other then an
          empty string in the else clause.
          • 2. Re: Any SQL geniuses out there?
            Level 7
            Yeah, got the same thing and it worked. Thanks
