0 Replies Latest reply on Jul 22, 2014 5:43 AM by Dapeamel
    backup indesign files
    Dapeamel Level 1
      Hello everyone
      I have a script there is a dialog box where you select indd files, you want to copy,
      you select a target, it creates a folder with same name as the folder from the selected indd files are located.
      also copying the .indd files there.
      example:
      Source
      C:/342123/source/batch1/test.indd
      copy to /342123/inter/återvinning/
      Result.
      c:/342123/inter/återvinning/batch1/test.indd
      the script also write a textfile with all the filenames of the copied indd files, the textfile been saved as the same folder as target.
      here is the problem..
      See code below:
      function copyfiles()
        var myPath = (File($.fileName).parent.parent.parent.fullName);
        var jobName=(myPath); // filtrera bort jobbnummret för att kunna plocka parrent from aktiv path.
        var _files = new File(jobName).openDlg("Select indd files to copy","*.indd",true);
        TargetFolder= Folder.selectDialog("Välj Target var filerna skall hamna"),  //vart filen skall hamna
        _parent = _files[0].parent.toString().replace(_files[0].parent.parent,"");
        new Folder(TargetFolder+ _parent).create();  //skapar mappen med namnet*
        var filenames = "";
        var txtfile = new File(TargetFolder+ _parent + "/myFileLog.txt");  // skapar en txt fil i mappen som skapas
        for(var i=0;i<_files.length;i++)
        _files[i].copy(new File(TargetFolder+ _parent + "/" + _files[i].name));
        filenames +=_files[i].name + "\r";
        txtfile.open('w');
        txtfile.write(filenames);
        txtfile.close();
      We have a filestructure which is always the same even for different jobs.
      I have wrote a script that creates structure the backup folderstructure
      See code below
      function Createfolders()
      var myPath = (File($.fileName).parent.parent.parent.fullName).split("/Kommuni/LaRe/LareAUTO/"); // här är en array som består av två element, den splittas
      var jobName=(myPath[1]); // sedan tar väljer jag andra elementet i arrayn (jobbnr) för att kunna plocka parrent from aktiv path.
      // här börjar alla enskilda mappar
      new Folder("/Volumes/Arkiv/Laredoute_BACKUP/" + jobName + "/_project_BACKUP").create(); ;
      new Folder("/Volumes/Arkiv/Laredoute_BACKUP/" + jobName + "/_project_BACKUP/TM_Big Book_BACKUP").create(); ;
      new Folder("/Volumes/Arkiv/Laredoute_BACKUP/" + jobName + "/blåkopior i 34xxxx_BACKUP").create(); ;
      new Folder("/Volumes/Arkiv/Laredoute_BACKUP/" + jobName + "/delivery_BACKUP").create(); ;
      new Folder("/Volumes/Arkiv/Laredoute_BACKUP/" + jobName + "/delivery_BACKUP/PDF_BACKUP").create(); ;
      new Folder("/Volumes/Arkiv/Laredoute_BACKUP/" + jobName + "/script_BACKUP").create(); ;
      When we copy files it's always in the folderstructure,
      here is a example how it works now:
      Source
      C:/342123/inter/atervinning/batch1/test.indd
      copy to
      I want my script to copy to this location to(my backup)
      copy to
      L:/inter/atervinning_backup/batch1/backupp_test.indd
      the script have always to know where the file is,
      and also the step
      here are few examples the way I want it to be
      source
      342123/inter/atervinning/batch3/
      target
      c:/342123/inter/efterredigering/
      result
      C:/342123/inter/efterredigering/batch3/
      L:/342123/inter/efteredigering/batch3/
      Example 2
      source
      342123/source/download/batch1/
      target
      342123/source/inter/
      result
      342123/source/inter/batch1/
      L:/34123/inter_backup/batch1/
      Does anyone have a solution?
