3 Replies Latest reply on Aug 29, 2007 7:46 AM by Newsgroup_User
    How do I pass a variable to a constructor?
      If I have a CFC like the one below:
      <cfcomponent>
      <!--- call init() automatically when the CFC is instantiated --->
      <cfset init()>
      <cffunction name="init" access="public" output="no" returntype="shoppingCart">
      <cfargument name="cartID" type="UUID" required="yes" >
      <cfset variables.cartID = arguments.cartID>
      <cfreturn this>
      </cffunction>
      </cfcomponent>
      ...how do I pass a requried variable to the constructor? (I am using Flex as my front end with Flash Remoting to call my CFCs so I won't be instantiating this from ColdFusion).
      Any help appreciated....
        • 1. Re: How do I pass a variable to a constructor?
          Level 7
          > <cfcomponent>
          > <cfset init()>
          > <cfreturn this>
          > </cffunction>
          > </cfcomponent>
          You would have an <mx:method...> in your <mx:RemoteObject...> for the
          init function in the CFC. Then you will need to call this from the
          appropriate place in your flex application. Maybe in a function called
          with the creationComplete event.
          • 2. Re: How do I pass a variable to a constructor?
            Say for example I have the following CFC called test.cfc:
            <cfcomponent>
            <cfset init()>
            <cffunction name="init" access="public" output="no" returntype="test">
            <cfargument name="cartID" type="numeric" required="yes" >
            <cfreturn this>
            </cffunction>
            </cfcomponent>
            ...and I have the following CFM file that calls it.....test.cfm.....
            <cfobject component="test" name="comp">
            <cfset comp.init(6)>
            <cfdump var="#comp.init(6)#">
            This will cause an error saying the parameter cartID to function init() was required but not passed in, because the constructor call ( <cfset init()> ) does not pass a parameter to the init function. The only way I can get this to work is to comment out the <cfset init()> line. I guess I don't need this in my scenario because I'm calling the init method directly anyway.
            FYI: I've been following Ben Fortas phone selector example ( a good example of building a simple Flex/CF app):
            http://www.adobe.com/devnet/flex/articles/coldfusionflex_part3_02.html
            • 3. Re: How do I pass a variable to a constructor?
              Level 7
              Yes you would not use the <cfset init()> line in the pseudo constructor.
              Then, as you where doing in your cfml example, you will call init()
              directly in your code.
              Then to translate this to your mxml, you would put a <mx:method
              name="init" ...> tag in your <mx:remoteObject... tag block. Then as
              some relevant part of your code you would call the init() method in your
              mxml. Very likely on some creationComplete() event.
              One thing to remember, without using more sophisticated techniques, a
              CFC can not maintain state when using remote calls. This is true for
              flex|flash remoting or web services. In other words you can't make one
              call to a method to set a value, then make another call to return the
              value when using remote methods.
