0 Replies Latest reply on Jul 23, 2014 1:13 PM by InMarketing
    How to get the exact size of a Indesign document into a slug info box
    InMarketing Level 1
      Hey guys,
      I have this following code to get my slug box automatically filled out with an applescript:
      set mgDate to do shell script "date '+%d/%m/%y'"
      tell application "Adobe InDesign CS6"
          tell active document
              set mgPath to file path as string
              set mgName to name
              set text item delimiters of AppleScript to ":"
              set mgShortName to text item 1 of mgName
              set text item delimiters of AppleScript to "_"
              set mgClient to text item 3 of mgShortName
              set mgCode to text item 1 of mgShortName
              set mgTypeDoc to text item 5 of mgShortName
              set mgRetailer to text item 4 of mgShortName
              set mgJobNumber to text item 2 of mgShortName
              set text item delimiters of AppleScript to default
              repeat with mgPage from 1 to count pages
                  set mgWidth to item 4 of bounds of page mgPage
                  set mgWidth to mgWidth as integer
                  set mgHeight to item 3 of bounds of page mgPage
                  set mgHeight to mgHeight as integer
                  set mgDimensions to ((mgWidth as string) & "x" & mgHeight as string) & "inches"
                  set active page of layout window 1 to page mgPage
                  tell active page of layout window 1
                      try -- check to see that correct SLUG is on the page
                          set mgFrame to ((text frame 1 of group 1) whose label is "SLUG")
                      on error
                          try
                              set mgFrame to (text frame 1 whose label is "SLUG")
                          on error
                              display dialog "Your SLUG should be in place on every page." & return & return & "(Note : the correct SLUG has been given a script label to help with automation)"
                          end try
                      end try
                      tell table 1 of mgFrame
                          set contents of cell 2 of row 1 to mgCode
                          set contents of cell 6 of row 1 to mgClient
                          set contents of cell 4 of row 1 to mgDate
                          set contents of cell 8 of row 1 to mgTypeDoc
                          set contents of cell 2 of row 2 to mgJobNumber
                          set contents of cell 6 of row 2 to mgRetailer
                          set contents of cell 8 of row 2 to mgDimensions
                          set contents of cell 4 of row 3 to mgPage as string
                          if contents of cell 4 of row 2 is "#" then
                              set contents of cell 4 of row 2 to "1"
                          else
                              set contents of cell 4 of row 2 to (contents of cell 4 of row 2) + 1 as string
                          end if
                      end tell
                  end tell
              end repeat
          end tell
      end tell
      When I run this applescript, it rounds up the decimal number of document size.... For example, for Us letter size, instead writing down 8.5 it will put 9 in.
      Does somebody know how to fix that?
      I also want my applescript says automatically if the document size is in Inches or Pixels, or centimeters. Thanks for your help!!!!!
      Sorry for my english, I am french!
