This content has been marked as final.
Show 2 replies
1. Re: LOOKUP function?
George_Johnson Jul 23, 2014 6:19 PM (in response to NiobeDMX)It sure can, but you'll have to implement it in JavaScript. I just finished up a project that does much the same, so post again if you need more help, and include bit more detail.
2. Re: LOOKUP function?
NiobeDMX Jul 25, 2014 8:35 PM (in response to George_Johnson)Thanks for your quick response George, as soon as I get the initial form made, I will post it here so you can give a more in-depth response, Also, is there a simple script that I can use that is similar to an Excel "if" "then" statement? For example, I want to have 2 check boxes and if check box #1 is checked, when the user clicks the "submit" button, the form is emailed to one address but if they check box#2, it would go to a different email address when they click "submit."
