3 Replies Latest reply: Jul 24, 2014 7:08 AM by Test Screen Name RSS
    different colour breakdown
    Cushion Print Management Community Member
      HI. I have recently updated to using Cloud. I still have an old version of Acrobat Pro on my machine and also the latest now. When I open a pdf in the old version and check on cmyk colour split it is exactly the same as it has been created in Indesign. The problem I have is with the latest version. When I open the same pdf in the latest version and view the same cmyk values they are different to what I have originally set up in Indesign (both old and new Acrobat viewing in US Web Coated (SWOP) V2 and showing different values). I have tried to change the settings in Indesign when creating a pdf to the same name settings in Acrobat and match them up. But still the cymk readings are not correct in Acrobat - not the same from the old version to the new and they should be exactly the same. Firstly how do I make the latest Acrobat show the colour colour split correctly. Secondly which is the name in the main settings in Indesign and Acrobat that I should be using to show the same colour split as originally set. At this rate I will not use the latest Acrobat but I should be able to. Please help. Jane
