10 Replies Latest reply on Jul 25, 2014 4:45 AM by Johnwhite
    Why this script unfunction?
    Johnwhite Level 1
      Hi, everyone
      can you find the wrong syntax of this script, and help me to fix it?
      app.findGrepPreferences = app.changeGrepPreferences = null;
      var doc = app.activeDocument,
          _selection = app.selection[0].words;
      var ignoreWords = "a, an, and, the, to, with, in, on, as, of, or, at, into, by, from, their, then, for, are, that, is, be";
      app.findGrepPreferences.appliedParagraphStyle = "01 H1";
          finds = app.selection[0].findGrep();
          for(var i=0;i<finds.length;i++){
          if(ignoreWords.indexOf(_selection[i].contents) == -1)
              finds[i].texts[0].changecase(ChangecaseMode.titlecase);
      John
        • 1. Re: Why this script unfunction?
          Jump_Over Level 5
          Does it return an error?
          The problem is with a logic, not with a syntax, I guess.
          How important is matching a paraStyle "01 H1"?
          Jarek
          • 2. Re: Why this script unfunction?
            Johnwhite Level 1
            Jarek
            I already have this script
            for(var i=0;i<_selection.length;i++)
                        _selection[i].changecase(ChangeCaseOptions.TITLECASE);
            but I change it into as before
            aim to search the heading only
            so, it's important
            John
            • 3. Re: Why this script unfunction?
              Jump_Over Level 5
              so only change you need is line 8:
              if(_selection[i].appliedParagraphStyle == "01 H1" && ignoreWords.indexOf(_selection[i].contents) == -1)
              I mean change in a code you had before
              Jarek
              • 4. Re: Why this script unfunction?
                Johnwhite Level 1
                Hi, Jarek
                I changed it
                but not anything response to me.
                John
                • 5. Re: Why this script unfunction?
                  Jump_Over Level 5
                  HI,
                  I  ment to change a code you had before (post no 2) -  not the one you messed up.
                  Jarek
                  • 6. Re: Why this script unfunction?
                    Johnwhite Level 1
                    Hi, Jarek
                    you mea this one:
                    still nothing
                    John
                    • 7. Re: Re: Why this script unfunction?
                      Jump_Over Level 5
                      I mean this one:
                      line 8 is modified
                      Jarek
                      • 8. Re: Why this script unfunction?
                        Johnwhite Level 1
                        Jarek
                        I testedm but still nothing
                        why?
                        John
                        • 9. Re: Re: Why this script unfunction?
                          Chinnadk Level 4
                          Hi John,
                          ".name" should be added in the 8th line with appliedParagraphStyle. Change the 8th line of Jarek's script as like below.
                          if(_selection[i].appliedParagraphStyle.name == "01 H1" && ignoreWords.indexOf(_selection[i].contents) == -1)
                          Regards,
                          Chinna
                          • 10. Re: Why this script unfunction?
                            Johnwhite Level 1
                            Thank you Chinna
                            Now it's working!
                            Thank you all guys
                            John
