4 Replies Latest reply on Jul 25, 2014 3:41 AM by manditacosmin
    can someone help me? I need a script code for Photoshop cs 6, that mirror all the layers in a group, not the group, every layer individual, please!
    manditacosmin
      I need a code script that mirror every layer in a group please!
        • 1. Re: can someone help me? I need a script code for Photoshop cs 6, that mirror all the layers in a group, not the group, every layer individual, please!
          cbuliarca Level 3
          Hi Costin,
          here is a jsx script that should do what you need I hope....:)
          You can change the pivot position as well or the mirror direction... check the command examples to see how.
            UL-------UC--------UR
            CL-------CC--------CR
            DL-------DC--------DR
            direction: 'Horizontal', 'Vertical', 'Both'
          command examples:
            bcm_mirrorAllCH(getSelectedLayersIdx(),'CC', 'Horizontal' );
            bcm_mirrorAllCH(getSelectedLayersIdx(),'UR', 'Both' );
          bcm_mirrorAllCH(getSelectedLayersIdx(),'CR', 'Horizontal' );
          function bcm_mirrorAllCH( idx,  pivotPos, mirrorDirection ){
               if( idx.constructor != Array ) idx = [ idx ];
               for( var a = 0; a < idx.length; a++ ){
                    var x = 0;
                    var y = 0;
                    var r = 0;
                    var i = idx[a];
                    for(i; i > 0 ; i--){
                         ref = new ActionReference();
                         ref.putIndex( charIDToTypeID( 'Lyr ' ), i );
                         var desc = executeActionGet(ref);
                         var layerName = desc.getString(charIDToTypeID( 'Nm  ' ));
                         var ls = desc.getEnumerationValue(stringIDToTypeID("layerSection"));
                         ls = typeIDToStringID(ls);
                         if(ls == "layerSectionStart"){ x++};
                         if(layerName.match(/^<\/Layer group/) )
                           y ++;
                           r = x - y;
                           if(r == 0 && ls == "layerSectionEnd"){break};
                           continue;
                         if(ls == "layerSectionContent"){mirrorByIndex( i, pivotPos, mirrorDirection )};
               multiSelectByIDx(idx);
          function mirrorByIndex( idx, pivotPos, mirrorDirection ){
          /*  pivot::
            Qst0----Qcs4-----Qcs1
            Qcs7----Qcsa-----Qcs5
            Qcs3----Qcs6-----Qcs2
            var piv = "Qcsa";
            switch(pivotPos){
              case "UL":
                piv = "Qst0";
                break;
              case "UC":
                piv = "Qcs4";
                break;
              case "UR":
                piv = "Qcs1";
                break;
              case "CL":
                piv = "Qcs7";
                break;
              case "CC":
                piv = "Qcsa";
                break;
              case "CR":
                piv = "Qcs5";
                break;
              case "DL":
                piv = "Qcs3";
                break;
              case "DC":
                piv = "Qcs6";
                break;
              case "DR":
                piv = "Qcs2";
                break;
            var dirr = {w:100, h:100};
            switch(mirrorDirection){
              case "Horizontal":
                dirr = {w:-100, h:100};
                break;
              case "Vertical":
                dirr = {w:100, h:-100};
                break;
              case "Both":
                dirr = {w:-100, h:-100};
                break;
            // alert(piv + " :: " + dirr.toSource());
            var idTrnf = charIDToTypeID( "Trnf" );
                var desc22 = new ActionDescriptor();
                var idnull = charIDToTypeID( "null" );
                    var ref14 = new ActionReference();
                ref14.putIndex(charIDToTypeID( "Lyr " ), idx);
                desc22.putReference( idnull, ref14 );
                var idFTcs = charIDToTypeID( "FTcs" );
                var idQCSt = charIDToTypeID( "QCSt" );
                var idQcsfive = charIDToTypeID( piv );
                desc22.putEnumerated( idFTcs, idQCSt, idQcsfive );
                var idOfst = charIDToTypeID( "Ofst" );
                    var desc23 = new ActionDescriptor();
                    var idHrzn = charIDToTypeID( "Hrzn" );
                    var idPxl = charIDToTypeID( "#Pxl" );
                    desc23.putUnitDouble( idHrzn, idPxl, 0.000000 );
                    var idVrtc = charIDToTypeID( "Vrtc" );
                    desc23.putUnitDouble( idVrtc, idPxl, 0.000000 );
                desc22.putObject( idOfst, idOfst, desc23 );
                var idWdth = charIDToTypeID( "Wdth" );
                var idPrc = charIDToTypeID( "#Prc" );
                desc22.putUnitDouble( idWdth, idPrc, dirr.w );
                var idHght = charIDToTypeID( "Hght" );
                desc22.putUnitDouble( idHght, idPrc, dirr.h );
                var idIntr = charIDToTypeID( "Intr" );
                var idIntp = charIDToTypeID( "Intp" );
                var idBcbc = charIDToTypeID( "Bcbc" );
                desc22.putEnumerated( idIntr, idIntp, idBcbc );
            executeAction( idTrnf, desc22, DialogModes.NO );
          function hasBackground(){// function to check if there is a background layer
              var res = undefined;
              try{
                  var ref = new ActionReference();
                  ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID("Nm  "));
                  ref.putIndex( charIDToTypeID("Lyr "), 0 );
                  executeActionGet(ref).getString(charIDToTypeID("Nm  ") );
                  res = true;
              }catch(e){ res = false}
              return res;
          function getSelectedLayersIdx(){// get the selected layers index( positon in layer editor)
               var selectedLayers = new Array;
               ref.putEnumerated( charIDToTypeID('Dcmn'), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
               var add = 1;
               if(hasBackground()){add = 0}
               if( desc.hasKey( stringIDToTypeID( 'targetLayers' ) ) ){
                    desc = desc.getList( stringIDToTypeID( 'targetLayers' ));
                    var c = desc.count
                    var selectedLayers = new Array();
                    for(var i=0;i<c;i++){
                         selectedLayers.push(  (desc.getReference( i ).getIndex()) + add);
               }else{
                    ref.putProperty( charIDToTypeID('Prpr') , charIDToTypeID( 'ItmI' ));
                    ref.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                    srs = hasBackground()?executeActionGet(ref).getInteger(charIDToTypeID( 'ItmI' ))-1:executeActionGet(ref).getInteger(charIDToTypeID( 'ItmI' ));
                    selectedLayers.push( srs);
               return selectedLayers;
          function multiSelectByIDx(idx) {
              var layers = new Array();
              var id54 = charIDToTypeID( "slct" );
              var desc12 = new ActionDescriptor();
              var id55 = charIDToTypeID( "null" );
              var ref9 = new ActionReference();
              for (var i = 0; i < idx.length; i++) {
                    layers[i] = charIDToTypeID( "Lyr " );
                    ref9.putIndex(layers[i], idx[i]);
              desc12.putReference( id55, ref9 );
              var id58 = charIDToTypeID( "MkVs" );
              desc12.putBoolean( id58, false );
              executeAction( id54, desc12, DialogModes.NO );
          • 2. Re: can someone help me? I need a script code for Photoshop cs 6, that mirror all the layers in a group, not the group, every layer individual, please!
            manditacosmin Level 1
            this is awesome, the only problem is that when it mirror the object it moves it an I need it to stay in the same place, If you have time and tell me how to make it, I am new to scripting and I find it very hard to understand
            • 3. Re: can someone help me? I need a script code for Photoshop cs 6, that mirror all the layers in a group, not the group, every layer individual, please!
              cbuliarca Level 3
              Right now the command use the pivot point for the transform on the Center right part you can change this line:
              with this:
