4 Replies Latest reply on Jul 25, 2014 7:49 AM by Teetan VK
    How Can find numbers and make it plus 1
    Teetan VK Level 1
      Hi, everyone
      I want find a bunch of numbers in my slection and then make it + 1
      for instance:
      aged (\d\d)
      I want to make it + 1
      and
      201(\d)
      what's the syntax?
      thanks
      VK
        • 1. Re: How Can find numbers and make it plus 1
          Chinnadk Level 4
          Hi VK,
          Try this. It finds the number in the selection and adds one to it, for example it finds "aged (20)", "201(2)" and will replace it to "aged (21)", 201(3) respectively .
          var _selection = app.selection[0];
          app.findGrepPreferences = changeGrepPreferences = null;
          app.findGrepPreferences.findWhat = "(aged) (\\(\\d\\d\\))";
          var found = app.selection[0].findGrep();
          for(var i=0;i<found.length;i++)
                  app.findGrepPreferences.findWhat = "\\d\\d";
                  var foundnum = found[i].findGrep();
                  var newnum = parseInt(foundnum[0].contents) + 1;
                  app.changeGrepPreferences.changeTo = newnum.toString();
                  found[i].changeGrep();
          app.findGrepPreferences.findWhat = "201\\(\\d\\)";
          var found1 = app.selection[0].findGrep();
          for(var i=0;i<found1.length;i++)
                  app.findGrepPreferences.findWhat = "\\d\\)";
                  var foundnum = found1[i].findGrep();
                  app.changeGrepPreferences.changeTo = newnum.toString() + ")";
                  found1[i].changeGrep();
          Regards,
          Chinna
          • 2. Re: How Can find numbers and make it plus 1
            Teetan VK Level 1
            Hi, Chinna
            I really appreciate for your help!
            thank you so much
            Regards,
            VK
            • 3. Re: How Can find numbers and make it plus 1
              Peter Kahrel Adobe Community Professional & MVP
              Chinna,
              You need to process the found array back to front, like this:
              for (var i = found1.length-1; i >= 0; i--)
              because if you don't, you get problems when the found numbers change length ( 9 > 10, 99 > 100).
              Peter
              • 4. Re: How Can find numbers and make it plus 1
                Teetan VK Level 1
                thanks Peter
                but I got no any problem,
                it runs perfectly
                VK
