2 Replies Latest reply on Jul 24, 2014 11:39 AM by InMarketing
    How to add document size value to a slug info box?
    InMarketing
      Hey guys,
      I an using an apple script to fill out automatically my slug box information with the following script:
      set mgDate to do shell script "date '+%d/%m/%y'"
      tell application "Adobe InDesign CS6"
          tell active document
              set mgPath to file path as string
              set mgName to name
              set text item delimiters of AppleScript to ":"
              set mgShortName to text item 1 of mgName
              set text item delimiters of AppleScript to "_"
              set mgClient to text item 3 of mgShortName
              set mgCode to text item 1 of mgShortName
              set mgTypeDoc to text item 5 of mgShortName
              set mgRetailer to text item 4 of mgShortName
              set mgJobNumber to text item 2 of mgShortName
              set text item delimiters of AppleScript to default
               repeat with mgPage from 1 to count pages
                  set mgWidth to item 4 of bounds of page mgPage
                  set mgWidth to mgWidth as integer
                  set mgHeight to item 3 of bounds of page mgPage
                  set mgHeight to mgHeight as integer
                  set mgDimensions to ((mgWidth as string) & "x" & mgHeight as string) & "inches"
            set active page of layout window 1 to page mgPage
                  tell active page of layout window 1
                      try -- check to see that correct SLUG is on the page
                          set mgFrame to ((text frame 1 of group 1) whose label is "SLUG")
                      on error
                          try
                              set mgFrame to (text frame 1 whose label is "SLUG")
                          on error
                              display dialog "Your SLUG should be in place on every page." & return & return & "(Note : the correct SLUG has been given a script label to help with automation)"
                          end try
                      end try
                  tell table 1 of mgFrame
                          set contents of cell 2 of row 1 to mgCode
                          set contents of cell 6 of row 1 to mgClient
                          set contents of cell 4 of row 1 to mgDate
                          set contents of cell 8 of row 1 to mgTypeDoc
                          set contents of cell 2 of row 2 to mgJobNumber
                          set contents of cell 6 of row 2 to mgRetailer
                          set contents of cell 8 of row 2 to mgDimensions
                          set contents of cell 4 of row 3 to mgPage as string
                          if contents of cell 4 of row 2 is "#" then
                              set contents of cell 4 of row 2 to "1"
                          else
                              set contents of cell 4 of row 2 to (contents of cell 4 of row 2) + 1 as string
                          end if
                      end tell
                  end tell
              end repeat
          end tell
      end tell
      My concern is this script makes the document size values rounded up to the closest decimal. For exemple if I am doing a 8.5x11 in document and I run the script,
      I will get 9x11 in in my slug box information. So I am looking for how to get the exact value? How could I also fill out automatically the units? For example, Something i am using Inches and sometimes Pixels.
      My actual script just allows to use Inches.... How could I fix that?
      Thanks you so much for your help and sorry for my english!
      Vincent
        • 1. Re: How to add document size value to a slug info box?
          Mary Posner Level 3
          You're explicitly telling it to round when you coerce the height and width to integers. If you want decimals, leave it as is, without the coercion.
          The second item might be a bit trickier, since it's possible to have different settings for the horizontal and vertical rulers. You could easily capture the units each uses and use those to construct your mgDimensions variable, e.g.
            set mgHUnits to horizontal measurement units of view preferences
          ... but that's going to make the Dimensions statement a bit clunky, e.g. "8.5 inches x 11.0 inches".
          You might consider having the script prompt you to select a measurement unit at the top of the script, have it enforce that that's the unit being used for both rulers, and then get your dimensions.
          • 2. Re: How to add document size value to a slug info box?
            InMarketing Level 1
            Hey Mary,
            I have added some changes to the original applescript I found on internet but i amnot able to find out where I am supposed to change the copy....
            Could you please correct my actual script with the revised lines you have suggested?
            I would really appreciate if you can help me out.
            Thank you!!!
