4 Replies Latest reply on Jul 25, 2014 9:29 AM by Jimbo_godsell
    Photoshop cs2 wont load
    Jimbo_godsell
      Hey having a problem with cs2, suddenly it wont load. It just bounces up and down in the dock and nothing happens, then it just stops bouncing.
      My computer slows down a bit while this happens. Image ready works fine however.
      I have a mac mini running os 10.4.11 with 2gb ram and a 1.83ghz intel dual core processor.
      Hope someone can help.
      James.
        • 1. Re: Photoshop cs2 wont load
          Does your Mac generate any kind of crash report if it does if may have some useful information "bounces" may be an indication that CS2 crashed.
          • 2. Re: Photoshop cs2 wont load
            Jimbo_godsell Level 1
            hey looked at the crash report and this is what i got
            Mac OS X Version 10.4.11 (Build 8S2167)
            2014-07-24 18:38:45 +0100
            2014-07-24 18:38:49.435 SystemUIServer[261] lang is:en
            Jul 24 18:39:47 james-godsells-computer /usr/sbin/ocspd: starting
            dyld: Library not loaded: @executable_path/../Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
            Referenced from: /Applications/image and animation/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2
            Reason: image not found
            2014-07-24 19:04:18.116 SystemUIServer[339] lang is:en
            Disk Utility started.
            Verifying volume “GOD”
            Checking HFS Plus volume.
            Checking Extents Overflow file.
            Checking Catalog file.
            Invalid node structure
            The volume GOD needs to be repaired.
            Error: The underlying task reported failure on exit
            Disk Utility stopped verifying “GOD” because the following error was encountered:
            1 HFS volume checked
            Volume needs repair
            Jul 24 19:27:13 james-godsells-computer authexec: executing /System/Library/ScriptingAdditions/StandardAdditions.osax/Contents/MacOS/uid
            Repairing permissions for “GOD”
            Determining correct file permissions.
            Permissions repair complete
            The privileges have been verified or repaired on the selected volume
            Volume needs repair
            • 3. Re: Photoshop cs2 wont load
              Look like your disk is bad or had some problems which were repaired to a point However CS2 is not fixed.  If the disk is useable download the replacement CS2 and install https://www.adobe.com/cfusion/entitlement/index.cfm?e=cs2_downloads
              • 4. Re: Photoshop cs2 wont load
                Yeah, ok all works fine now thanks allot. The other problem is in the process of being fixed as well.
                Thanks for the advice.
