1 Reply Latest reply on Jul 25, 2014 1:24 AM by duncancumming
    cfsearch filename
      Is there a way to retrieve just the document filename without the appended url path from a cfsearch?
        • 1. Re: cfsearch filename
          duncancumming Level 3
          • what, if anything, have you specified on the URLPath attribute of your cfindex?
          • what column are you referring to in your cfsearch results?   You might want to post a sample of what you get if you dump out a row from the results so we can see all the columns.
          Couple of ideas.
          • You could use the custom1..4 attributes when doing the cfindex to populate the collection with those filenames.  These can then be referenced in your cfsearch results.
          • Or, you could use a simple regex to extract just the filename, or even something like listLast(url, "/")
