4 Replies Latest reply on Jul 24, 2014 4:07 PM by Teetan VK
    A script third part unfunction can you fix it?
    Teetan VK Level 1
      Hi, everyone
      I got this script:
      var
        mySelected = Number( app.extractLabel("mDialog") ),
        myDialog = app.dialogs.add({name:"Colse files save \"Yes\" or \"No\"",canCancel:true});
        with(myDialog){
             with(dialogColumns.add()){
                  with(dialogRows.add()){
                       var
                       mySelection = dropdowns.add({stringList:["01   Yes", "02   No", "03   Reverse"], selectedIndex: 0});
      if (myDialog.show() == true)
          main();
      myDialog.destroy();
      function main(){
            colse_file();
      function colse_file(){
          var docs = app.documents;
          for (var i = docs.length-1; i >= 0; i--) {
              docs[i].close(SaveOptions.YES);
          if (mySelection.selectedIndex == 1){
              docs[i].close(SaveOptions.NO);
         if (mySelection.selectedIndex == 2){
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.neverInteract;
      app.documents.everyItem().revert();
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
      3rd part: revert
      unfunction
      can you fix it?
      VK
        • 1. Re: A script third part unfunction can you fix it?
          pixxxel schubser MVP & Adobe Community Professional
          Hmmh?
          What do you really want?
          Please try something like this:
          var aDoc = app.activeDocument;
          if (aDoc.saved) {
          aDoc.revert();
          } else { alert ("unsaved document");}
          This reverts the document to its state at the last save operation.
          Have fun
          • 2. Re: A script third part unfunction can you fix it?
            Jump_Over Level 5
            Fixing a provided code - since if (mySelection.selectedIndex == 0) condition is missed ==>all doc are saved regardless of user choice. So reverting may look like saving after OP's code does a job...
            ...may look but does not work since all doc are closed as well.
            Jarek
            • 3. Re: Re: A script third part unfunction can you fix it?
              @Jump_Over,
              that's right.
              But the logic of this script isn't really good.
              IMHO this (only quick and dirty, and not tested saving and closing) should be a little bit better:
              //var mySelected = Number( app.extractLabel("mDialog") ),
                var myDialog = app.dialogs.add({name:"Colse files save \"Yes\" or \"No\"",canCancel:true});
                with(myDialog){
                               var mySelection = dropdowns.add({stringList:["01   Yes", "02   No", "03   Reverse"], selectedIndex: 0});
              if (myDialog.show() == true) {
                  main();
                  myDialog.destroy();
              function main(){
              if (mySelection.selectedIndex == 0){
                    //colse_file();
                    save_file();
                    return;
                    close_file();
                    return;
                    revert_file();
                    return;
              function save_file(){ // colse_file()
                      //return;
                      } return; //edited, the return was on a wrong place before
              function close_file(){
                      //return;
              function revert_file(){
                     return;
              • 4. Re: A script third part unfunction can you fix it?
                Teetan VK Level 1
                thanks all guys
                thank you so much
                VK
