1 Reply Latest reply on Jul 24, 2014 12:50 PM by TᴀW
    How do I add a leader to a right indent tab?
    Schmaltzkopf Level 1
      Hi. I know that if I insert a regular tab and give it a leader, I can then replace it with a right-indent tab, and the leader will stay there, but is there a way to give the right-indent tab a leader as you insert it in the text?
      Any help would be appreciated.
        • 1. Re: How do I add a leader to a right indent tab?
          TᴀW Adobe Community Professional & MVP
          Yes, you can. With your cursor in the paragraph, open the Tabs window,
          and add a regular tab anywhere, and set its leader to whatever you want.
          You'll find that now right-indent tabs get that leader too.
          That's a bit of funny way to do it, admittedly, but I think the logic is
          as follows: the Leader string is a property of a TabStop object. If a
          Paragraph object has no TabStops, then all the Leaders are undefined. So
          you need to add at least one TabStop to a paragraph to be able to define
          at least one leader. Once you've got that, the right-indent tab (which
          does not require a TabStop) can pick up its leader from the TabStop
          you've added, even though there's no real connection between them.
          Of course, this raises the question: If there is more than one TabStop
          in a paragraph, which leader will the right-indent tab pick up?
          Okay, so having experimented a little, it appears that a right-indent
          tab get the leader belonging to the last TabStop in the paragraphs
          TabStop collection. Which makes a kind of sense I suppose (well, they'd
          need to choose one of them).
          Anyway, the answer to your actual question is in the first paragraph...
