2 Replies Latest reply on Jul 25, 2014 4:17 AM by JJMack
    The alternative does not exist!
    sangvinista
      I'm trying to convert folders of pictures to CMYK. (File>Automate>Batch) But the action "Convert RGB to CMYK" does not exist... WHY?
        • 1. Re: The alternative does not exist!
          Doc Maik Level 4
          Because programming something you can easily create yourself does not make sense?
          Create an action to convert RGB to CMYK and then use that action in batch conversion.
          • 2. Re: The alternative does not exist!
            Automate batch dialog is used to batch an Action.  Could it be that your using an action that has a recorded Automate Batch step and that action or action set recorded into that batch step is not currently in you actions palette?
            I think all a convert to CMYK action would need to be is a single insert menu item  "Image>Mode>CMYK Color".
            It is it sensible to batch something that is easy to do when you have many files you need converted..
