4 Replies Latest reply on May 1, 2007 5:12 AM by Newsgroup_User
    Help: Casting String gotten from Xml to a Number Type
    kevmann16
      Hi all,
      I have a major problem, I have parsed the data from an xml doc to global vars in flash and need to use a few of them as numbers for things the position of "nodes" on the screen. However I can not cast the data stored as a var to a number or int value.
      For example in the code below when the set Node button is pressed it traces the "Node's" current X value, then the value in the global var gotten from the xml, which contains the x position of where to place the Node.
      Next it creates a new var of Number Type and assigns it the Number value of the string in global var.
      It then traces the new value of SNtopLeftX and sets the x pos of the Node's movie clip to the value of SNtopLeftX
      However the Node doesn't move and this is the output I get from the traces
      Start Node is at x = -734.5
      nod_topLeftX is 16
      TopLeftX = 16
      SN TopLeftX = NaN
      I do not understand why I am getting NaN when the string of nod_topLefX is 16, any ides?
        • 1. Re: Help: Casting String gotten from Xml to a Number Type
          Level 7
          you got some casing mixed up:
          nod_topLeftX
          Number(nod_TopLeftX);
          lower "t" one time, upper the other.
          Manno
          kevmann16 wrote:
          > Hi all,
          > nod_topLeftX is 16
          > TopLeftX = 16
          > SN TopLeftX = NaN
          > any ides?
          > butNodeSet.onRelease = function() {
          > trace ("Start Node is at x = " + mcStartNode._x);
          > trace ("nod_topLeftX is " + nod_topLeftX);
          > var SNtopLeftX:Number = Number(nod_TopLeftX);
          > trace ("StartNode TopLeftX = " + SNtopLeftX);
          > mcStartNode._x = SNtopLeftX;
          Manno Bult
          http://www.aloft.nl
          manno@xs4all.nl
          • 2. Re: Help: Casting String gotten from Xml to a Number Type
            kevmann16 Level 1
            Thank you for your help but it made no difference. Even if I use the line:
            _global.nod_topLeftX = Number(xmlDoc_xml.firstChild.childNodes[3].childNodes[0].childNodes[3].childNodes[0]);
            So it selects the number value as I import it I get Is NaN if I trace nod_topLeftX
            • 3. Re: Help: Casting String gotten from Xml to a Number   Type
              Level 7
              A small adaptation (code below) from your first example
              * corrected typo in Number() parameter
              * no xml
              * movieClip called mcStartNode on stage
              does what I would expect. Sure there's no other typo's or scope issues?
              function test() {
              nod_topLeftX = "0";
              trace ("nod_topLeftX is " + nod_topLeftX + "; type: " + typeof
              nod_topLeftX );
              trace(nod_topLeftX + " to Number renders " + nod_topLeftX);
              var SNtopLeftX:Number = Number(nod_topLeftX);
              test();
              kevmann16 wrote:
              > Hi,
              > s[0]);
              > nod_topLeftX
              Manno Bult
              http://www.aloft.nl
              manno@xs4all.nl
              • 4. Re: Help: Casting String gotten from Xml to a Number Type
                kevmann16 Level 1
                I've managed to gwet it working with help, I can force it to an integer using:
                _global.nod_topLeftX = parseInt(xmlDoc_xml.firstChild.childNodes[3].childNodes[0].childNodes[3].childNodes[0]);
