1 Reply Latest reply on May 1, 2007 7:36 AM by peterent
    Copying Datagrid row problem
    ChickenSupreme
      im trying to copy a datagrid row and add it to the datagrid using the following code:
      userList.addItem(userList.getItemAt(myDataGrid.selectedIndex));
      where:
      myDataGrid is a datagrid and userList is an ArrayCollection which is the datagrids dataprovider.
      What i notice is that after copying, the first row is no longer clickable, and i notice in the debugger that the new row has the same reference value as the first row. How does one get around this? Do i need to recreated the content of the row into a new object before adding it to userList?
      Thanks in advance
      Eric
        • 1. Re: Copying Datagrid row problem
          peterent Level 2
          If you want to copy a record from a DataGrid's dataProvider you do it like this:
          var item:Object = userList.getItemAt( myDataGrid.selectedIndex );
          item is now a reference to the object at the specified location. It is *not* a copy. You have to manually copy the object. There is an object copy function in mx.utils.ObjectUtil which can help.
          var copy:Object = mx.utils.ObjectUtil( item );
          now add that item to the dataProvider:
          userList.addItem( copy );
