1 Reply Latest reply on Aug 27, 2015 1:19 AM by *Scatz*
    Is it possible to apply workflow on the webform?
    informaat
        • 1. Re: Is it possible to apply workflow on the webform?
          *Scatz* Level 1
          Go to the form, click edit properties and then select "Use Workflow" to specify a workflow to use on form submission
          Or alternatively you can use the code below directly in the code of your form if you need to be able to choose from a range of workflows that can be triggered when user submits the form.
          <select name="WorkflowList" >
              <option value=" - id of workflow 1 goes in here - ">
                     "Option 1 Text"
             </option>
              <option value=" - id of workflow 2 goes in here - ">
                    "Option 2 Text"
             </option>
            </select>
          I thought there was an article in this inside the documentation on this but i'm afraid I couldn't find you the link.
          Best of luck
