13 Replies Latest reply on Jul 26, 2014 6:18 AM by Teetan VK
    Why the alert massage return twice on the screen?
    Teetan VK Level 1
      Hi, everyone
      I got this script:
      var
        mySelected = Number( app.extractLabel("mDialog") ),
        myDialog = app.dialogs.add({name:"Colse files save \"Yes\" or \"No\"",canCancel:true});
        with(myDialog){
             with(dialogColumns.add()){
                  with(dialogRows.add()){
                       var
                       mySelection = dropdowns.add({stringList:["01   Yes", "02   No", "03   Reverse"], selectedIndex: 0});
      if (myDialog.show() == true)
          main();
      myDialog.destroy();
      function main(){
            colse_file();
      function colse_file(){
          if (mySelection.selectedIndex == 0){
      var docs = app.documents;
          for (var i = docs.length-1; i >= 0; i--) {
              docs[i].close(SaveOptions.YES);
      alert("Done.\rAll files are saved.");
          if (mySelection.selectedIndex == 1){
              docs[i].close(SaveOptions.NO);
      alert("Done.\rAll files are closed without save.");
         if (mySelection.selectedIndex == 2){
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.neverInteract;
      app.documents.everyItem().revert();
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
      alert("Done.\rAll files are reversed.");
      VK
        • 1. Re: Why the alert massage return twice on the screen?
          Chinnadk Level 4
          Hi VK,
          Place this line into the "if condition" it is lying outside the "if condition" that why it returns alert twice
          • 2. Re: Why the alert massage return twice on the screen?
            Teetan VK Level 1
            Hi, Chinna
            I changed it into this:
            var
              with(myDialog){
                             var
                main();
            myDialog.destroy();
            function main(){
                  colse_file();
            but I still got twice
            VK
            • 3. Re: Why the alert massage return twice on the screen?
              Chinnadk Level 4
              It is working fine here check again.
              • 4. Re: Why the alert massage return twice on the screen?
                Teetan VK Level 1
                even worse, close every file got once on screen.
                • 5. Re: Why the alert massage return twice on the screen?
                  Jump_Over Level 5
                  Even worse - you can see them as many times as many doc are opened - notice a differences between your 1st and 2nd code.
                  Are you writing them online?
                  Your alerts are inside for...loop now.
                  Jarek
                  • 6. Re: Why the alert massage return twice on the screen?
                    Sajeev Sridharan Level 4
                    Dont change anything in your script, just replace last three lines:
                    Vandy
                    • 7. Re: Why the alert massage return twice on the screen?
                      Teetan VK Level 1
                      so what is the solution to fix it?
                      • 8. Re: Why the alert massage return twice on the screen?
                        place the last alert message inside the closing curly brackets,
                        Like below:
                        Vandy
                        • 9. Re: Why the alert massage return twice on the screen?
                          Teetan VK Level 1
                          Hi, Vandy
                          I want three alerts for each function
                          no just one
                          thanks
                          VK
                          • 10. Re: Re: Why the alert massage return twice on the screen?
                            pixxxel schubser Level 5
                            Hmmh?
                            Same problem as your last thread - the logic of your script isn't really good!!!
                            Why you do not use the structure I showed you there: A script third part unfunction can you fix it?
                            Here is the script I've posted there (extended now with alerts)
                            //var mySelected = Number( app.extractLabel("mDialog") ),
                              var myDialog = app.dialogs.add({name:"Colse files save \"Yes\" or \"No\"",canCancel:true});
                              with(myDialog){
                                             var mySelection = dropdowns.add({stringList:["01   Yes", "02   No", "03   Reverse"], selectedIndex: 0});
                            if (myDialog.show() == true) {
                                main();
                                myDialog.destroy();
                            function main(){
                                  //colse_file();
                                  save_file();
                                    // for save function
                                    //alert("saved")
                                  return;
                                  close_file();
                                    // for close function
                                    //alert("saved")
                                  return;
                                  revert_file();
                                    // for reverse function
                                    //alert("saved")
                                  return;
                            function save_file(){ // colse_file()
                                    // for every file
                                    //alert("saved")
                                    } return; // sorry, the return was on the wrong place before
                            function close_file(){
                                    // for every file
                                    //alert("closed")
                            function revert_file(){
                                   // this is not a loop
                                   //alert("reversed")
                                   return;
                            Activating the alerts you want should easy fix your problem.
                            Have fun
                            • 11. Re: Why the alert massage return twice on the screen?
                              Teetan VK Level 1
                              schubser
                              thank you so much
                              VK
                              • 12. Re: Why the alert massage return twice on the screen?
                                You' re welcome.
                                (Oh, there are two little mistakes in my last posting:
                                line 30 should be "close" and
                                line 36 should be "reversed" in the alert)
                                Have a nice day
                                • 13. Re: Why the alert massage return twice on the screen?
                                  Teetan VK Level 1
                                  thanks schubser,
                                  I got your idea, but not use your script, I know the syntax now, thank you so much.
                                  but after use the idea, that's conflict to the UndoModes.FAST_ENTIRE_SCRIPT function
                                  app.doScript('main()', ScriptLanguage.JAVASCRIPT, undefined, UndoModes.FAST_ENTIRE_SCRIPT, "Indent Paragraphs");
                                  because I joint 12 scripts together,
                                  but some script need to undo, but some are not to be undo.
                                  so that's a lot conflict to the UndoModes.FAST_ENTIRE_SCRIPT function
                                  can you fix it?
                                  https://forums.adobe.com/thread/1531927
                                  VK
