0 Replies Latest reply on Jul 25, 2014 5:28 AM by todd_rohrer
    Actionscript gets deleted on publish (or move)?
    todd_rohrer Level 1
      Increasingly in the last few weeks, I've experienced a weird issue where I save or publish a copy of a file I'm working on, and then seemingly random bits of my actionscript are deleted.
      For example, on my original save, my Actions looked like this:
      // ========== INIT ===========//
      //Load the client's logo
      mcLogo.loadMovie(_global.dplocal.customizedDataPath + "logo_large.swf");
      //Show debug Version info if we're running in standalone mode...
      if(_parent == undefined) {
          mcVersionInfo._visible = true;
      } else {
          mcVersionInfo._visible = false;
      *          Retrieve the customized data path, and remove any leading navigation characters.
      *          Next, check if the video is a custom video (its contentPath is not the default
      *          thank you video), that it has not been corrected yet, and that this SWF was opened
      *          by another SWF; if all are true, then add the folder name to the beginning of the
      *          content path.
      var customFolder = _global.dplocal.customizedDataPath;
      while(customFolder.StartsWith(".") || customFolder.StartsWith("\\") || customFolder.StartsWith("/"))
                  customFolder = customFolder.slice(1);
      var debugMessage = "\r##### Forms Complete / Thank-You Video - Start #####" +
                                                         "\r#  customizedDataPath:  " + _global.dplocal.customizedDataPath +
                                                         "\r#  customFolder:  " + customFolder +
                                                         "\r#  contentPath (before):  " + mcPlayer.contentPath;
      if(mcPlayer.contentPath != "thank_you2.flv" && !mcPlayer.contentPath.StartsWith(customFolder) && _parent != undefined)
                  mcPlayer.contentPath = customFolder + mcPlayer.contentPath;
      debugMessage += "\r#  contentPath (after):  " + mcPlayer.contentPath +
                                                      "\r#####  Forms Complete / Thank-You Video - End  #####";
      debug(debugMessage);
      but after saving or publishing (I'm not sure which is the issue), it got cut down to this:
      } else {
      I didn't touch the actions during my edit.  Sometimes it removes a large amount of code like that, other times it seemed to be only a line or two.
      Is there a reason why this gets removed?  Is there something I could do to prevent it?
