12 Replies Latest reply on Jul 27, 2014 3:59 AM by Jump_Over
    How can I show the swatches.everyItem in the dropdown list
    Johnwhite Level 1
      Hi, everyone
      Can you correct my script, aim to let it show the swatches.everyItem in the dropdown list
      if ( app.selection.length > 0 && ( app.selection[0].constructor.name == "Cell" || app.selection[0].constructor.name == "Table" ) ) {
          if ( app.scriptPreferences.version >= 6 ) {
              app.doScript(main, ScriptLanguage.JAVASCRIPT , [], UndoModes.ENTIRE_SCRIPT, "style every second column in selection" );
          else {
              main();
      } else {
          alert ( "Nothing or wrong selection!" );
      //---------------------------------------------------------------------------------------- --------------has some prolems in this part
      var sN = doc.swatches.everyItem ().name,
          sID = doc.swatches.everyItem ().id,
      function main() {
         var l, c = 0, o, p, pO = {}, pA = [];
           if (s == null) {alert("No Swatch Selected") ; return;};               // I want to show swatches.everyItem.name as myColor
          s = doc.swatches.itemByID (sID[s.index]);
          var myFillTint = 20;
          var myCharStyleName = "Bold";
          var myStrokeWeight = 0.5;
          var curSel = app.selection[0];
          var allCells = curSel.cells;
          var startCol = curSel.cells[0].name.split(":")[0]*1;
          var endCol = curSel.cells[-1].name.split(":")[0]*1;
          var startRow = curSel.cells[0].name.split(":")[1]*1;
          var endRow = curSel.cells[-1].name.split(":")[1]*1;
          var counter = startCol + 1;
          for ( var i = 0 ; i < allCells.length; i++ ) {
              var curCell = allCells[i];
              var curCol = curCell.name.split(":")[0]*1;
              var curRow = curCell.name.split(":")[1]*1;
              if ( curCol == counter ) {
                  with ( curCell ) {
                      fillColor = myColor;
                      fillTint = myFillTint;
                      texts[0].appliedCharacterStyle = myCharStyleName;
                      rightEdgeStrokeWeight = myStrokeWeight;
                      rightEdgeStrokeColor= myColor;
                      leftEdgeStrokeWeight = myStrokeWeight;
                      leftEdgeStrokeColor= myColor;
                  if ( curRow == startRow ) {
                      curCell.topEdgeStrokeWeight = myStrokeWeight;
                      curCell.topEdgeStrokeColor= myColor;
                  else if (curRow == endRow ) {
                      curCell.bottomEdgeStrokeWeight = myStrokeWeight;
                      curCell.bottomEdgeStrokeColor= myColor;
                  counter = counter + 2;
              if ( counter > endCol ) {
              } // end if
          } // end for
      } // end main
      John
        • 1. Re: How can I show the swatches.everyItem in the dropdown list
          Jump_Over Level 5
          Looks like careless copy-pasted.
          function main() {
            var l, c = 0, o, p, pO = {}, pA = [];      //    var declared but not used
              if (s == null)                           //    var used but not declared
          Jarek
          • 2. Re: How can I show the swatches.everyItem in the dropdown list
            Johnwhite Level 1
            Hi, Jarek
            How can fix it?
            John
            • 3. Re: How can I show the swatches.everyItem in the dropdown list
              Jump_Over Level 5
              How can fix it?
              John.
              1st at all - a main part of your code is trying to format cells in a selection, which looks like out of your subject's goal..
              2nd - there is no even one line in your code which is trying to show a list of swatches to user.
              3rd - your code's main logic is - do main() if some condition == true and do main() if this condition ==  false.
              4th - your code is executing main() function with no variables declared.
              There is nothing to fix, I am afraid. Better to create it from an empty point.
              Jarek
              • 4. Re: How can I show the swatches.everyItem in the dropdown list
                Johnwhite Level 1
                Hi Jarek,
                the orginal script is:
                        app.doScript( main, ScriptLanguage.JAVASCRIPT , [], UndoModes.ENTIRE_SCRIPT, "style every second column in selection" );
                    else {
                        main();
                } else {
                function main() {
                    var myColor = "Black";
                            with ( curCell ) {
                        } // end if
                    } // end for
                } // end main
                I want to add a function aim to show my swatches.everyItem then I selected a colour for fillColor
                How can I do that
                John
                • 5. Re: Re: How can I show the swatches.everyItem in the dropdown list
                  Jump_Over Level 5
                  John,
                  In this case your main function should start with a dialog window to take user choice.
                  The rest of function stay as it is. So:
                  function main() {
                  var
                    w = new Window("dialog","What is your choice", undefined, {closeButton: false}),
                    mPanel1 = w.add ("panel",undefined, "choose a color"),
                    mPanel2 = w.add ("panel",undefined, "choose a charStyle"),
                    mCoList = mPanel1.add("dropdownlist",undefined,app.activeDocument.swatches.everyItem().name),
                    mStyList = mPanel2.add("dropdownlist",undefined,app.activeDocument.characterStyles.everyItem().name),
                    b = w.add("group");
                    mCoList.items[0].selected = mStyList.items[0].selected = true;
                    w.alignChildren= "left";
                    b.add ("button", undefined, "OK", {name: "ok"});
                    b.add ("button", undefined, "Anuluj", {name: "cancel"});
                    if (w.show()) {
                    var mColor = mCoList.selection.text;
                    var mCharStyleName = mStyList.selection.text;
                    else exit();
                   // var ...
                  Jarek
                  • 6. Re: How can I show the swatches.everyItem in the dropdown list
                    Johnwhite Level 1
                    Hi Jarek,
                    I changed it into this:
                    but I got an error.
                            app.doScript( main, ScriptLanguage.JAVASCRIPT , [], UndoModes.ENTIRE_SCRIPT, "style every second column in selection" );     // the error source is this line
                        else {
                            main();
                    } else {
                    function main() {
                    var
                      mStyList = mPanel2.add("dropdownlist",undefined,app.activeDocument.characterStyles.everyItem().name) ,
                      b = w.add("group");
                      if (w.show()) {
                      else exit();
                                with ( curCell ) {
                            } // end if
                        } // end for
                    } // end main
                    how can fix it?
                    John
                    • 7. Re: How can I show the swatches.everyItem in the dropdown list
                      Jump_Over Level 5
                      ... what error? paste the message
                      Jarek
                      • 8. Re: How can I show the swatches.everyItem in the dropdown list
                        Johnwhite Level 1
                        Hi Jarek
                        myColor undefined
                        but the error source is:
                        I don't konw why
                        John
                        • 9. Re: How can I show the swatches.everyItem in the dropdown list
                          Jump_Over Level 5
                          check var names and share the same version:
                               mColor vs myColor
                               mCharStyleName vs myCharStyleName
                          (are you going to use a 2nd dropDownList as well?)
                          Notice that I am just showing the way. I am not an end_product_supplier.
                          Jarek
                          • 10. Re: How can I show the swatches.everyItem in the dropdown list
                            Johnwhite Level 1
                            sorry Jarek
                            I made two typos
                            now it works
                            thank you so much,
                            and very very sory
                            John
                            • 11. Re: How can I show the swatches.everyItem in the dropdown list
                              Johnwhite Level 1
                              Hi jarek
                              inspire by your idea
                              I want and need to add the dropdown list for FillTint percentage
                              and point of the StrokeWeight
                              and stroke color
                              can you please give me an idea
                              Regard
                              John
                              • 12. Re: How can I show the swatches.everyItem in the dropdown list
                                Jump_Over Level 5
                                Idea is given already
                                All you need is to add next object to a dialog instead of "hard-defining" variable.
                                Try yourself!    ... and enjoy scripting
                                Jarek
