Greetings!
We just began using AMS for live streaming with HLS and we encouter some serious issues. Our first commercial live event is scheduled to next Wednesday and we cannot afford to lose our customer so your help is greatly appreciated.
We have two issues which are probably related :
Again your help is greatly appreciated. On a side note we would be happy to purchase per-incident support from Adobe to solve the issue asap but it looks it's not available anymore. Anybody from the staff feel free to PM me about it.
Link : http://www.webtv.coop/group/Test-WebTV/f9b9c899885569fa901a787fcdb08568
User : test
Pass : test
Thanks a bunch,
Ph.
edge.00.log
#Version: 1.0
#Start-Date: 2014-07-25 00:02:45
#Software: Adobe Media Server 5.0.3 r3029 x64
#Date: 2014-07-25
#Fields: date time x-pid x-status x-ctx x-comment
2014-07-25 00:02:40 28648 (i)2581173 Host: videodb.webtv.coop IPv4: 10.2.2.8 -
2014-07-25 00:02:40 28648 (i)2631180 Info from AccessAdaptor: Access Adaptor started /opt/adobe/ams/modules/access/libconnect.so. -
2014-07-25 00:02:40 28648 (e)2631013 Failed to create listener for adaptor backup_defaultRoot_, IP localhost, port 19350: TCCommBridge::createListener 127.0.0.1:19350/v4: bind failed!!!. -
2014-07-25 00:02:40 28648 (e)2631013 Failed to create listener for adaptor backup_defaultRoot_, IP , port 1935: TCCommBridge::createListener 0.0.0.0:1935/v4: bind failed!!!. -
2014-07-25 00:02:40 28648 (e)2631114 Failed to start listeners for adaptor backup_defaultRoot__edge1. -
2014-07-25 00:02:40 28648 (e)2791225 Failed to start edge : backup_defaultRoot__edge1 -
#Date: 2014-07-25
2014-07-25 00:04:50 28847 (i)2581173 Host: videodb.webtv.coop IPv4: 10.2.2.8 -
2014-07-25 00:04:50 28847 (i)2631180 Info from AccessAdaptor: Access Adaptor started /opt/adobe/ams/modules/access/libconnect.so. -
2014-07-25 00:04:50 28847 (e)2631013 Failed to create listener for adaptor backup_defaultRoot_, IP localhost, port 19350: TCCommBridge::createListener 127.0.0.1:19350/v4: bind failed!!!. -
2014-07-25 00:04:50 28847 (e)2631013 Failed to create listener for adaptor backup_defaultRoot_, IP , port 1935: TCCommBridge::createListener 0.0.0.0:1935/v4: bind failed!!!. -
2014-07-25 00:04:50 28847 (e)2631114 Failed to start listeners for adaptor backup_defaultRoot__edge1. -
2014-07-25 00:04:50 28847 (e)2791225 Failed to start edge : backup_defaultRoot__edge1 -
#Date: 2014-07-25
2014-07-25 00:07:00 29817 (i)2581173 Host: videodb.webtv.coop IPv4: 10.2.2.8 -
2014-07-25 00:07:00 29817 (i)2631180 Info from AccessAdaptor: Access Adaptor started /opt/adobe/ams/modules/access/libconnect.so. -
2014-07-25 00:07:00 29817 (e)2631013 Failed to create listener for adaptor backup_defaultRoot_, IP localhost, port 19350: TCCommBridge::createListener 127.0.0.1:19350/v4: bind failed!!!. -
2014-07-25 00:07:00 29817 (e)2631013 Failed to create listener for adaptor backup_defaultRoot_, IP , port 1935: TCCommBridge::createListener 0.0.0.0:1935/v4: bind failed!!!. -
2014-07-25 00:07:00 29817 (e)2631114 Failed to start listeners for adaptor backup_defaultRoot__edge1. -
2014-07-25 00:07:00 29817 (e)2791225 Failed to start edge : backup_defaultRoot__edge1 -
#Date: 2014-07-25
2014-07-25 00:09:10 30014 (i)2581173 Host: videodb.webtv.coop IPv4: 10.2.2.8 -
2014-07-25 00:09:10 30014 (i)2631180 Info from AccessAdaptor: Access Adaptor started /opt/adobe/ams/modules/access/libconnect.so. -
2014-07-25 00:09:10 30014 (e)2631013 Failed to create listener for adaptor backup_defaultRoot_, IP localhost, port 19350: TCCommBridge::createListener 127.0.0.1:19350/v4: bind failed!!!. -
2014-07-25 00:09:10 30014 (e)2631013 Failed to create listener for adaptor backup_defaultRoot_, IP , port 1935: TCCommBridge::createListener 0.0.0.0:1935/v4: bind failed!!!. -
2014-07-25 00:09:10 30014 (e)2631114 Failed to start listeners for adaptor backup_defaultRoot__edge1. -
2014-07-25 00:09:10 30014 (e)2791225 Failed to start edge : backup_defaultRoot__edge1
core.00.log
#Version: 1.0
#Start-Date: 2014-07-25 09:56:08
#Date: 2014-07-25
2014-07-25 09:56:08 18327 (w)2581173 /opt/adobe/ams/applications/livepkgr/events/_definst_/canal91event/Event.xml does not exist or is invalid. -
master.00.log
#Version: 1.0
#Start-Date: 2014-07-25 00:00:33
#Date: 2014-07-25
2014-07-25 00:00:30 17555 (i)2581226 Edge (28097) is no longer active. -
2014-07-25 00:00:30 17555 (w)2581255 Edge (28097) backup_defaultRoot__edge1 experienced 1 failure! -
2014-07-25 00:00:30 17555 (i)2581224 Edge (28338) started, arguments : -edgeports ":1935" -coreports "localhost:19350" -conf "/opt/adobe/ams/conf/Server.xml" -adaptor "backup_defaultRoot_" -$
2014-07-25 00:02:40 17555 (i)2581226 Edge (28338) is no longer active. -
2014-07-25 00:02:40 17555 (w)2581255 Edge (28338) backup_defaultRoot__edge1 experienced 1 failure! -
2014-07-25 00:02:40 17555 (i)2581224 Edge (28648) started, arguments : -edgeports ":1935" -coreports "localhost:19350" -conf "/opt/adobe/ams/conf/Server.xml" -adaptor "backup_defaultRoot_" -$
2014-07-25 00:04:50 17555 (i)2581226 Edge (28648) is no longer active. -
2014-07-25 00:04:50 17555 (w)2581255 Edge (28648) backup_defaultRoot__edge1 experienced 1 failure! -
2014-07-25 00:04:50 17555 (i)2581224 Edge (28847) started, arguments : -edgeports ":1935" -coreports "localhost:19350" -conf "/opt/adobe/ams/conf/Server.xml" -adaptor "backup_defaultRoot_" -$
2014-07-25 00:07:00 17555 (i)2581226 Edge (28847) is no longer active. -
ams.ini
# ams.ini contains substitution variables for Adobe Media Server #
# configuration files. Lines beginning with '#' are considered comments. #
# A substitution variable is in the form <name>=<value>. Everything up to #
# the first '=' is considered the name of the substitution variable, and #
# everything after the first '=' is considered the substitution value. If #
# you want a substitution variable to have leading or trailing spaces, #
# enclose the value around double quotes. For example, foo=" bar " #
# This section contains configurable parameters in Server.xml #
# Username for server admin
# For example:
# SERVER.ADMIN_USERNAME = foo
SERVER.ADMIN_USERNAME = admin
# IP address and port Adobe Media Admin Server should listen on
# For example:
# SERVER.ADMINSERVER_HOSTPORT = :1111
# User id in which to run the process (Linux Only)
# For example:
# SERVER.PROCESS_UID = 500
# Group id in which to run the process (Linux Only)
# For example:
# SERVER.PROCESS_GID = 500
# License key for Adobe Media Server
# For example:
# SERVER.LICENSEINFO = XXXX-XXXX-XXXX-XXXX-XXXX-XXXX
SERVER.LICENSEINFO = (license goes here)
# LIVE_DIR denotes the full path of sample "Live" application's
# folder for storing any live stream recorded by server.
# For example:
# LIVE_DIR = <AMS_Installation_Dir>\applications\live
LIVE_DIR = /opt/adobe/ams/applications/live
# VOD_COMMON_DIR denotes the full path of sample "VOD" application's
# folder for storing onDemand and Progressive Download .flv/.mp3 files.
# File stored in this folder can be streamed and are also PD-able.
# Note : If you are using the default installation of Apache as a webserver,
# and if you modify VOD_COMMON_DIR, please change the document root
# accordingly in httpd.conf.
# For example:
# VOD_COMMON_DIR = <AMS_Installation_Dir>\webroot\vod
VOD_COMMON_DIR = /opt/adobe/ams/webroot/vod
# VOD_DIR denotes the full path of sample "VOD" application's
# folder for storing onDemand only .flv/.mp3 files. Files stored in
# this folder are not PD-able
# For example:
# VOD_DIR = <AMS_Installation_Dir>\applications\vod\media
VOD_DIR = /opt/adobe/ams/applications/vod/media
# The maximum size of the FLV cache, in megabytes.
# The default is 500MB.
SERVER.FLVCACHE_MAXSIZE=500
# Whether to start and stop the included HTTP server along
# with AMS.
SERVER.HTTPD_ENABLED = true
# Whether to start and stop the cache cleaning tool along
# with HTTP server.
SERVER.HTCACHECLEAN_ENABLED = true
# The path specifying the cache root for webserver caching.
SERVER.HTCACHEROOT = /opt/adobe/ams/Apache2.2/cacheroot
# This section contains configurable parameters in Adaptor.xml #
# IP address and port(s) Adobe Media Server should listen on
# For example:
# ADAPTOR.HOSTPORT = :1935,80
# IP (address and) port that Adobe Media Server should proxy
# unknown HTTP requests to. Leave empty to disable proxying.
# With no address, specifies a localhost port.
# For example:
# HTTPPROXY.HOST = webfarm.example.com:80
HTTPPROXY.HOST = :8134
#This tag specifies an IP address for the player to use instead of a hostname when
#making the RTMPT connection to AMS. If nothing is specified, AMS will automatically
#determine the IP to use.
ADAPTOR.HTTPIDENT2 =
# This section contains configurable parameters in Vhost.xml #
# Application directory for the virtual host
# For example:
# VHOST.APPSDIR = C:\myapps
VHOST.APPSDIR = /opt/adobe/ams/applications
# This section contains configurable parameters in Application.xml #
# List of semi-colon delimited paths in which to search for script to load
# For example:
# APP.JS_SCRIPTLIBPATH = C:\scripts;C:\Program Files\Foo\scripts
APP.JS_SCRIPTLIBPATH = /opt/adobe/ams/scriptlib
# This section contains configurable parameters in Logger.xml #
LOGGER.LOGDIR =
# This section contains configurable parameters in Users.xml #
# Enable or disable using HTTP requests to execute admin commands.
# Set to "true" to enable, otherwise it will be disabled. The
# actual commands permitted for server admin and virtual host admin
# users can be set in Users.xml.
USERS.HTTPCOMMAND_ALLOW = true
FMLE screencaps :
Update : point 1. above has been resolved. After investigation we found out that was a player issue.
Point 2 still needs to be addressed please (random service shutdown).
Help would be greatly appreciated! Staff?
Can you stop AMS and run the following command to see if any other process is using ports 1935 and 19350?
netstat -tulpn
Most probably, you would see some process linked to these ports due to which AMS is not able to bind to these ports. Please kill these processes and start AMS.
Thanks Charles.
Strange thing. Here is the netstat output. Ports 1935 and 19350 are already taken by AMS :
[root@videodb ~]# netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:2049 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:5666 0.0.0.0:* LISTEN 22502/nrpe
tcp 0 0 127.0.0.1:8005 0.0.0.0:* LISTEN 27901/java
tcp 0 0 0.0.0.0:8134 0.0.0.0:* LISTEN 15093/httpd
tcp 0 0 127.0.0.1:11110 0.0.0.0:* LISTEN 29001/./amsadmin
tcp 0 0 0.0.0.0:806 0.0.0.0:* LISTEN 8256/rpc.statd
tcp 0 0 0.0.0.0:807 0.0.0.0:* LISTEN 27760/rpc.rquotad
tcp 0 0 127.0.0.1:199 0.0.0.0:* LISTEN 8765/snmpd
tcp 0 0 0.0.0.0:8009 0.0.0.0:* LISTEN 27901/java
tcp 0 0 0.0.0.0:3306 0.0.0.0:* LISTEN 12980/mysqld
tcp 0 0 0.0.0.0:1935 0.0.0.0:* LISTEN 15098/amsedge
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 8123/portmap
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 15093/httpd
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 27901/java
tcp 0 0 0.0.0.0:819 0.0.0.0:* LISTEN 27776/rpc.mountd
tcp 0 0 127.0.0.1:19350 0.0.0.0:* LISTEN 15098/amsedge
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 8790/sshd
tcp 0 0 0.0.0.0:1111 0.0.0.0:* LISTEN 29001/./amsadmin
tcp 0 0 0.0.0.0:49209 0.0.0.0:* LISTEN -
tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 9323/master
udp 0 0 0.0.0.0:2049 0.0.0.0:* -
udp 0 0 10.2.2.8:1935 0.0.0.0:* 15098/amsedge
udp 0 0 127.0.0.1:1935 0.0.0.0:* 15098/amsedge
udp 0 0 0.0.0.0:57615 0.0.0.0:* -
udp 0 0 10.2.2.8:19350 0.0.0.0:* 15098/amsedge
udp 0 0 127.0.0.1:19350 0.0.0.0:* 15098/amsedge
udp 0 0 0.0.0.0:800 0.0.0.0:* 8256/rpc.statd
udp 0 0 0.0.0.0:161 0.0.0.0:* 8765/snmpd
udp 0 0 0.0.0.0:802 0.0.0.0:* 27760/rpc.rquotad
udp 0 0 0.0.0.0:803 0.0.0.0:* 8256/rpc.statd
udp 0 0 0.0.0.0:816 0.0.0.0:* 27776/rpc.mountd
udp 0 0 0.0.0.0:49875 0.0.0.0:* 10305/avahi-daemon
udp 0 0 0.0.0.0:5353 0.0.0.0:* 10305/avahi-daemon
udp 0 0 0.0.0.0:111 0.0.0.0:* 8123/portmap
udp 0 0 10.2.2.8:123 0.0.0.0:* 8824/ntpd
udp 0 0 127.0.0.1:123 0.0.0.0:* 8824/ntpd
udp 0 0 0.0.0.0:123 0.0.0.0:* 8824/ntpd
But still the same errors in edge.00.log where it looks like edge tries to start a new connection to those same ports every 2 minutes and 10 seconds.
#Date: 2014-07-31
2014-07-31 09:20:24 10369 (i)2581173 Host: videodb.webtv.coop IPv4: 10.2.2.8 -
2014-07-31 09:20:24 10369 (i)2631180 Info from AccessAdaptor: Access Adaptor started /opt/adobe/ams/modules/access/libconnect.so. -
2014-07-31 09:20:24 10369 (e)2631013 Failed to create listener for adaptor backup_defaultRoot_, IP localhost, port 19350: TCCommBridge::createListe$
2014-07-31 09:20:24 10369 (e)2631013 Failed to create listener for adaptor backup_defaultRoot_, IP , port 1935: TCCommBridge::createListener 0.0.0.$
2014-07-31 09:20:24 10369 (e)2631114 Failed to start listeners for adaptor backup_defaultRoot__edge1. -
2014-07-31 09:20:24 10369 (e)2791225 Failed to start edge : backup_defaultRoot__edge1 -
#Date: 2014-07-31
2014-07-31 09:22:34 10662 (i)2581173 Host: videodb.webtv.coop IPv4: 10.2.2.8 -
2014-07-31 09:22:34 10662 (i)2631180 Info from AccessAdaptor: Access Adaptor started /opt/adobe/ams/modules/access/libconnect.so. -
2014-07-31 09:22:34 10662 (e)2631013 Failed to create listener for adaptor backup_defaultRoot_, IP localhost, port 19350: TCCommBridge::createListe$
2014-07-31 09:22:34 10662 (e)2631013 Failed to create listener for adaptor backup_defaultRoot_, IP , port 1935: TCCommBridge::createListener 0.0.0.$
2014-07-31 09:22:34 10662 (e)2631114 Failed to start listeners for adaptor backup_defaultRoot__edge1. -
2014-07-31 09:22:34 10662 (e)2791225 Failed to start edge : backup_defaultRoot__edge1 -
#Date: 2014-07-31
2014-07-31 09:24:44 10900 (i)2581173 Host: videodb.webtv.coop IPv4: 10.2.2.8 -
2014-07-31 09:24:44 10900 (i)2631180 Info from AccessAdaptor: Access Adaptor started /opt/adobe/ams/modules/access/libconnect.so. -
2014-07-31 09:24:44 10900 (e)2631013 Failed to create listener for adaptor backup_defaultRoot_, IP localhost, port 19350: TCCommBridge::createListe$
2014-07-31 09:24:44 10900 (e)2631013 Failed to create listener for adaptor backup_defaultRoot_, IP , port 1935: TCCommBridge::createListener 0.0.0.$
2014-07-31 09:24:44 10900 (e)2631114 Failed to start listeners for adaptor backup_defaultRoot__edge1. -
2014-07-31 09:24:44 10900 (e)2791225 Failed to start edge : backup_defaultRoot__edge1
An earlier running instance of AMS seems to be occupying ports 1935 and 19350. Can you please kill these manually with the following command:
kill 15098
Once again verify that these ports are no longer occupied by any process using
netstat -tulpn
Kill all AMS related process, if still running. Now start AMS. It should work fine.
Thanks again Charles. I will try this once I got a suitable timeframe for this operation from the broadcasting team.
Will report!
Cheers.
Hi again everyone.
Thanks Charles for offering a solution but unfortunately still not working. Please see details below.
Netstat while AMS running :
[root@videodb ams]# netstat -tulpn
tcp 0 0 127.0.0.1:8005 0.0.0.0:* LISTEN 19768/java
tcp 0 0 0.0.0.0:8134 0.0.0.0:* LISTEN 2309/httpd
tcp 0 0 0.0.0.0:8009 0.0.0.0:* LISTEN 19768/java
tcp 0 0 0.0.0.0:1935 0.0.0.0:* LISTEN 8690/amsedge
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 19768/java
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 2309/httpd
tcp 0 0 127.0.0.1:19350 0.0.0.0:* LISTEN 8690/amsedge
udp 0 0 10.2.2.8:1935 0.0.0.0:* 8690/amsedge
udp 0 0 127.0.0.1:1935 0.0.0.0:* 8690/amsedge
udp 0 0 10.2.2.8:19350 0.0.0.0:* 8690/amsedge
udp 0 0 127.0.0.1:19350 0.0.0.0:* 8690/amsedge
Stopping server :
[root@videodb ams]# ./server stop
NPTL 2.5
Stopping Adobe Media Server (please check /var/log/messages)
Server has shutdown...
Netstat after shutdown (ports 1935 and 19350 are free) :
Restart :
[root@videodb ams]# ./server start
NPTL 2.5
Starting Adobe Media Server (please check /var/log/messages)
Content of edge.00.log :
#Version: 1.0
#Start-Date: 2014-08-06 14:39:17
#Date: 2014-08-06
2014-08-06 14:39:12 15099 (i)2581173 Host: videodb.webtv.coop IPv4: 10.2.2.8 -
2014-08-06 14:39:12 15099 (i)2631180 Info from AccessAdaptor: Access Adaptor started /opt/adobe/ams/modules/access/libconnect.so. -
2014-08-06 14:39:12 15099 (i)2631174 Listener started ( backup_defaultRoot__edge1 ) : localhost:19350/v4 -
2014-08-06 14:39:13 15099 (i)2631174 Listener started ( backup_defaultRoot__edge1 ) : 1935/v4 -
2014-08-06 14:39:14 15099 (i)2631174 Listener started ( backup_defaultRoot__edge1 ) : 127.0.0.1:19350 (rtmfp-core)/v4 -
2014-08-06 14:39:14 15099 (i)2631174 Listener started ( backup_defaultRoot__edge1 ) : 10.2.2.8:19350 (rtmfp-core)/v4 -
2014-08-06 14:39:14 15099 (i)2631509 Public rtmfp-core addresses for listener backup_defaultRoot__edge1 are: 127.0.0.1:19350;10.2.2.8:19350 -
2014-08-06 14:39:14 15099 (i)2631174 Listener started ( backup_defaultRoot__edge1 ) : 127.0.0.1:1935 (rtmfp)/v4 -
2014-08-06 14:39:14 15099 (i)2631174 Listener started ( backup_defaultRoot__edge1 ) : 10.2.2.8:1935 (rtmfp)/v4 -
#Date: 2014-08-06
2014-08-06 14:39:12 15097 (i)2581173 Host: videodb.webtv.coop IPv4: 10.2.2.8 -
2014-08-06 14:39:12 15097 (i)2631180 Info from AccessAdaptor: Access Adaptor started /opt/adobe/ams/modules/access/libconnect.so. -
2014-08-06 14:39:12 15097 (e)2631013 Failed to create listener for adaptor _defaultRoot_, IP localhost, port 19350: TCCommBridge::createListener 127.0.0.1:19350/v4: bind failed!!!$
2014-08-06 14:39:12 15097 (e)2631013 Failed to create listener for adaptor _defaultRoot_, IP , port 1935: TCCommBridge::createListener 0.0.0.0:1935/v4: bind failed!!!. -
2014-08-06 14:39:12 15097 (e)2631114 Failed to start listeners for adaptor _defaultRoot__edge1. -
2014-08-06 14:39:12 15097 (e)2791225 Failed to start edge : _defaultRoot__edge1 -
#Date: 2014-08-06
2014-08-06 14:41:22 15903 (i)2581173 Host: videodb.webtv.coop IPv4: 10.2.2.8 -
2014-08-06 14:41:22 15903 (i)2631180 Info from AccessAdaptor: Access Adaptor started /opt/adobe/ams/modules/access/libconnect.so. -
2014-08-06 14:41:22 15903 (e)2631013 Failed to create listener for adaptor _defaultRoot_, IP localhost, port 19350: TCCommBridge::createListener 127.0.0.1:19350/v4: bind failed!!!$
2014-08-06 14:41:22 15903 (e)2631013 Failed to create listener for adaptor _defaultRoot_, IP , port 1935: TCCommBridge::createListener 0.0.0.0:1935/v4: bind failed!!!. -
2014-08-06 14:41:22 15903 (e)2631114 Failed to start listeners for adaptor _defaultRoot__edge1. -
2014-08-06 14:41:22 15903 (e)2791225 Failed to start edge : _defaultRoot__edge1
Content of var/log/messages :
Aug 6 14:39:11 videodb Service[15070]: Server starting...
Aug 6 14:39:12 videodb Server[15070]: /opt/adobe/ams/Apache2.2/bin/httpd -f ./conf/httpd.conf -d "/opt/adobe/ams/Apache2.2" -k start returned 0: [Wed Aug 06 14:39:11 2014] [info] mod_jithttp - AMS $
Aug 6 14:39:12 videodb Server[15070]: /opt/adobe/ams/Apache2.2/bin/htcacheclean -n -t -i -p/opt/adobe/ams/Apache2.2/cacheroot -d5 -l1024K returned 0:
Aug 6 14:39:12 videodb Adaptor[15097]: Failed to create listener for adaptor _defaultRoot_, IP localhost, port 19350: TCCommBridge::createListener 127.0.0.1:19350/v4: bind failed!!!.
Aug 6 14:39:12 videodb Adaptor[15099]: Listener started ( backup_defaultRoot__edge1 ) : localhost:19350/v4
Aug 6 14:39:12 videodb Adaptor[15097]: Failed to create listener for adaptor _defaultRoot_, IP , port 1935: TCCommBridge::createListener 0.0.0.0:1935/v4: bind failed!!!.
Aug 6 14:39:12 videodb Adaptor[15097]: Failed to start listeners for adaptor _defaultRoot__edge1.
Aug 6 14:39:12 videodb Edge[15097]: Failed to start edge : _defaultRoot__edge1
Aug 6 14:39:12 videodb Service[15070]: Server started (/opt/adobe/ams/conf/Server.xml).
Aug 6 14:39:13 videodb Adaptor[15099]: Listener started ( backup_defaultRoot__edge1 ) : 1935/v4
Aug 6 14:39:14 videodb Adaptor[15099]: Listener started ( backup_defaultRoot__edge1 ) : 127.0.0.1:19350 (rtmfp-core)/v4
Aug 6 14:39:14 videodb Adaptor[15099]: Listener started ( backup_defaultRoot__edge1 ) : 10.2.2.8:19350 (rtmfp-core)/v4
Aug 6 14:39:14 videodb Adaptor[15099]: Public rtmfp-core addresses for listener backup_defaultRoot__edge1 are: 127.0.0.1:19350;10.2.2.8:19350
Aug 6 14:39:14 videodb Adaptor[15099]: Listener started ( backup_defaultRoot__edge1 ) : 127.0.0.1:1935 (rtmfp)/v4
Aug 6 14:39:14 videodb Adaptor[15099]: Listener started ( backup_defaultRoot__edge1 ) : 10.2.2.8:1935 (rtmfp)/v4
Can you try restarting your machine?
Please ensure that only one instance of ams is running at anytime and kill all previously running ams processes before starting a new ams instance. Only one amsmaster process should be running at a given time.
You can use the following command to find ams processes running:
ps -aux | grep ams
