8 Replies Latest reply on Jul 25, 2014 3:50 PM by Peter Spier Branched from an earlier discussion.
    Cannot run InDesign!
    Stephoney Level 1
      I'm also having this problem.
      I've tried everything, re-installing, uninstalling, using the adobe clean tool, using a different username to sign in with ..... everything and there is no answer.
      I do not want to purchase a product if I cannot trial it test it and I'm certainly not paying for the full version if I am going to have the same issue!
      An answer would be nice.
        • 1. Re: Cannot run InDesign!
          BobLevine MVP & Adobe Community Professional
          We can’t help you without system details.
          • 2. Re: Cannot run InDesign!
            stephoney8286
            My system details are:
            Windows 7 home premium
            64 bit operating system
            Intel pentium CPU B950 @ 2.10ghz
            • 3. Re: Cannot run InDesign!
              I've branched this off to a new discussion.
              More details. What exactly are you doing? Have you downloaded a demo? What version of InDesign?
              How much RAM? Is Windows 7 updated to SP1?
              Are you getting error messages.
              That is a very, very low end processor.
              • 4. Re: Cannot run InDesign!
                Stephoney Level 1
                I am trying to do what initial discussion said, hence why I have commented on here.
                I have downloaded a trial version of InDesign CC through the Adobe Cloud. It loads up, goes through the loading process, actually opens up the software and then shuts down.
                I have 4GB of RAM.
                It is service pack 1.
                I'm not getting any error messages it just closes down.
                As for me having a low end processor I am a student and hardly see how this is relevant as I have Photoshop CS6 and have never had an issue with that running on my system.
                This also happened about 2 months ago with Illustrator when I tried to trial that again it didn't work so I didn't bother purchasing it in the end. I had hoped it wouldn't happen this time around.
                I just need a resolution to this as I need to trial it to see whether it is worth getting.... If I can get it to work and I get on with it I will buy it but I'm not wasting my time with it if it won't work.
                • 5. Re: Cannot run InDesign!
                  It could be a number of different problems. Is it shutting down while the splash screen is open? I suspect the installer has not set the correct permissions on the preference folders. You can find the folder locations from this link: Replace Your Preferences. Note that these are HIDDEN folders, so you need to set Explorer to show hidden files and folders. You can try renaming the two Adobe folders, then restart ID. Do NOT follow the instructions for replacing the prefs, just rename the folders.
                  • 6. Re: Cannot run InDesign!
                    Stephoney Level 1
                    Hi Peter,
                    It is shutting down just after the splash page and it actually loads the software up and then it just disappears. Then sometimes it will happen during the splash page loading, it varies. It is very tiring.
                    I will try your solution and let you know the outcome.
                    Many thanks.
                    • 7. Re: Cannot run InDesign!
                      Stephoney Level 1
                      Hi Peter,
                      I have just been into that folder .... the files that you say should be in there are not.
                      I go into the following C:\Users\AppData\Local\Adobe\InDesign\Version 10.0\en_GB
                      All that is in there is a hidden folder called Caches. Again hidden files are set to visible.
                      In the Cache folder are the following folder files.
                      InDesign Recovery
                      Scripting Support
                      TypeSupport
                      FindChangeData
                      FindChangeDataTmp
                      FontMaskCache
                      idletask
                      InDesign ClipboardScrap1
                      InDesign ClipboardScrap23
                      InDesign DragDropScap
                      InDesign SavedData.
                      I haven't deleted anything nor have I ever been in this file. Now I'm really confused.
                      • 8. Re: Cannot run InDesign!
                        Yes, that's the path to InDesign SavedData, and apparently it is being written, so this is not a permissions issue and renaming the folders probably won't help. Replacing the prefs might though, and certainly wont hurt, so you can follow the directions to rename the two files. You've found InDesing SavedData, now look in AppData\ROAMING\ (you were in AppData\Local) for the other folder.
                        If that doesn't do it, I suggest you post over in Community: Downloading, Installing, Setting Up | Adobe Community  where there are Adobe staffers monitoring the forum dedicated to install issues.
