0 Replies Latest reply on Jul 26, 2014 2:32 AM by hasvi
    How to 'import xml' in my script
    hasvi Level 1
      Hi All,
      Below "Script 1" is working fine, now I want to call the '.xml' file which was placed in Template folder(see script code).
      How to import xml in 'New.indd' file("Line 27:-->var source = File(path + '/New.indd')".
      Please add import xml code in 'Script 1"
      Script 1:
      var path = Folder.selectDialog ("Select folder");
      if(path==null)
      exit();
      var files = path.getFiles(/\.(indd?|indt?)$/i);
      if(files==0)
        alert("There is no 'indd'/'indt' file in your folder");
        exit();
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
      try
      myDocument = app.open(new File(files));
      MasterpageScriptLabel();
      TableCellStyleCreation();
      myDocument.save(new File(path + "/New.indd"));
      var folder = new Folder(path + '/Updated_Folder');
      folder.create();
      myDocument.close();
      var source = File(path + '/New.indd');
      var dest = new File(folder + '/New.indd');
      source.copy(dest);
      source.remove();
      catch(e)
      alert ("Your folder permissible only one file of 'INDD' or 'INDT' file");
      exit();
      function MasterpageScriptLabel()
      var myDoc=app.activeDocument;
      var myXMLElement=myDoc.xmlElements[0];
      if(myXMLElement.isValid)
          var myParentStory=myXMLElement.parentStory;
          var myTextContainers=myParentStory.textContainers;
          for(var i=0;i<myTextContainers.length;i++)
              myTextContainers[i].label="S_TF";
      var mspreads=myDoc.masterSpreads;
      for (i=0;i<mspreads.length;i++)
      if(mspreads[i].textFrames.length>1)
          var txfmlength=mspreads[i].textFrames;
          for (j=0;j<txfmlength.length;j++)
              if(txfmlength[j].nextTextFrame!=null)
              {txfmlength[j].label="S_TF";}
              if(txfmlength[j].previousTextFrame!=null)
      function TableCellStyleCreation()
          var cestyle = myDocument.cellStyles;
          var array = ["TBL_COLH", "TBL_BODY"];
          var i = array.length;
          while(i--)
                  try{
                      var style = myDocument.cellStyles.add();
                      style.name = array[i++];
                  catch(e)
                      style.remove();
                      alert("'" + array[i-1] + "'"+ " Already exists in the document.")
                  i--;
      main();
      function main(){
            var progress_win = new Window ("palette");
      var progress = progress_bar(progress_win, 2, 'Processing ... Completed');
          delay(1);
            progress.value = progress.value+1;
          delay(1);
          progress.parent.close();
      // delay function found here
      //found here http://www.wer-weiss-was.de/theme157/article1143593.html
        function delay(prmSec){
        prmSec *= 1000;
        var eDate = null;
        var eMsec = 0;
        var sDate = new Date();
        var sMsec = sDate.getTime();
        do {
        eDate = new Date();
        eMsec = eDate.getTime();
        } while ((eMsec-sMsec)<prmSec);
      * Taken from ScriptUI by Peter Kahrel
      * @param  {Palette} w    the palette the progress is shown on
      * @param  {[type]} stop [description]
      * @return {[type]}      [description]
      function progress_bar (w, stop, labeltext) {
      var txt = w.add('statictext',undefined,labeltext);
      var pbar = w.add ("progressbar", undefined, 1, stop);
      pbar.preferredSize = [300,20];
      w.show ();
      return pbar;
      by
      hasvi
