0 Replies Latest reply on Jul 26, 2014 3:58 AM by Teetan VK
    Conflict to UndoModes.FAST_ENTIRE_SCRIPT
    Teetan VK Level 1
      Hi, everyone
      I joint some scripts together, but some are conflict to the UndoModes.FAST_ENTIRE_SCRIPT:
      app.doScript('(mySelection.selectedIndex == 3)', ScriptLanguage.JAVASCRIPT, undefined, UndoModes.FAST_ENTIRE_SCRIPT, "multi tasking not at same time");
      Is that possible only add an undo function to specify script or two scripts?
      the first one has conflict with the UndoModes.FAST_ENTIRE_SCRIPT function.
      var
        mySelected = Number( app.extractLabel("mDialog") ),
        myDialog = app.dialogs.add({name:"Multi Tasking Wizard",canCancel:true});
        with(myDialog){
             with(dialogColumns.add()){
                  with(dialogRows.add()){
                       var
                       mySelection = dropdowns.add({stringList:["01   Batch import styles from source document", "02   Gen Revised-PDF", "03   Joint text fame together"], selectedIndex: 0});
      if (myDialog.show() == true)
      function main(){
            colse_file();
      function colse_file(){
         if (mySelection.selectedIndex == 0){
                var MyFolderWithFiles = Folder.selectDialog ("Choose a folder");
                var sourceFile = File.openDialog("Choose the styles source");
                var myFiles = MyFolderWithFiles.getFiles("*.indd");
                for(i = 0; i < myFiles.length; i++) {
                    theFile = myFiles[i];
                    app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
                    var targetDoc = app.open(theFile, true);
                    app.scriptPreferences.userInteractionLevel = UserInteractionLevels.INTERACT_WITH_ALL;
                    targetDoc.importStyles(ImportFormat.CHARACTER_STYLES_FORMAT, sourceFile, GlobalClashResolutionStrategy.LOAD_ALL_WITH_OVERWRITE);
                    targetDoc.importStyles(ImportFormat.PARAGRAPH_STYLES_FORMAT, sourceFile, GlobalClashResolutionStrategy.LOAD_ALL_WITH_OVERWRITE);
                    targetDoc.close(SaveOptions.YES);
         if (mySelection.selectedIndex == 1){
              var f = new Folder("~/Desktop/Revised_PDF put in here/");
              f.create();
              var doc = app.documents;
              app.findTextPreferences = null;
              app.findTextPreferences.underline = true;
              for(var i=0;i<doc.length;i++)
                      var found = doc[i].findText();
                      var _pages = [];
                      for(var j=0;j<found.length;j++)
                              var txfms = found[j].texts[0].parentTextFrames;
                              for(var k=0;k<txfms.length;k++)
                                      _pages.push(txfms[k].parentPage.name);
                      for(var j=0;j<_pages.length;j++)
                              if(_pages[j] === _pages[j-1])
                                      _pages.splice(j,1);
                      if(_pages.length != 0)
                              app.pdfExportPreferences.pageRange = _pages.toString();
                              doc[i].exportFile(ExportFormat.PDF_TYPE, new File("~/Desktop/Revised_PDF put in here/" + doc[i].name.replace(/\.indd$/i,".pdf")), false);
                      _pages = [];
              var f = Folder("~/Desktop/Revised_PDF put in here/" );
              f.execute();
         if (mySelection.selectedIndex == 3){
      var D_MARGIN = 6;
      var D_CONTROLHEIGHT = 20;
      var D_BUTTONWIDTH = 100;
      var D_CONTROLLABELWIDTH = 160;
      var D_CONTROLWIDTH = 150;
      var D_DIALOG_WIDTH = 400;
      var S2 = 1.41421356237309504880;
      function _odControlShared(label,name) {
          dialog = this;
          var y = dialog.curYPos;
          var itemHeight = D_CONTROLHEIGHT;
          var itemBump = itemHeight + D_MARGIN;
          if(label != "")
              label += ":";
          var labelCtl = dialog.add('statictext',[20,y,20 + D_CONTROLLABELWIDTH,y+itemHeight],label);
          labelCtl.justify = "right";
          var controlBox = new Object();
          controlBox.left = 20 + D_CONTROLLABELWIDTH + 10;
          controlBox.top = y;
          controlBox.right = controlBox.left + D_CONTROLWIDTH;
          controlBox.bottom = controlBox.top + itemHeight;
          dialog.curYPos = controlBox.bottom + D_MARGIN;
          return controlBox;
      function _odControlSharedFinish(control,name,valueFieldName) {
          oD = this;
          oD.items[name] = control;
          oD.itemValueFieldNames[name] = valueFieldName;
          oD.itemNames[oD.itemNames.length] = name;
      function _odNumber(label,name,value) {
          oD = this;
          var controlBox = oD._odControlShared(label,name);
          var control = oD.add('edittext',controlBox,value);
          control.value = value;
          control.onChange = function(){this.value = (this.text) * 1.0; this.text = this.value;};
          oD._odControlSharedFinish(control,name,"text");
          return control;
      function _odText(label,name,value) {
          oD = this;
          control.onChange = function(){this.value = this.text; };
          return control;
      function _setColorFromButton(victim,button) {
          var g = victim.graphics;
          var n = button.value;
          var myBrush = g.newBrush(g.BrushType.SOLID_COLOR, n);
          g.backgroundColor = myBrush;
      function _odColor(label,name,color) {
          oD = this;
          var swatchBox = [controlBox.left + 40,controlBox.top,controlBox.right,controlBox.bottom];
          var buttonBox = [controlBox.left,controlBox.top,controlBox.left + 30,controlBox.bottom];
          var swatch = oD.add('group',swatchBox);
          var button = oD.add('button',buttonBox);
          button.swatch = swatch;
          button.value = color;
          button.onClick = function(){
                  var n = doColorPicker(this.value);
                  this.value = n;
                  _setColorFromButton(swatch,this);
          _setColorFromButton(swatch,button);
          oD._odControlSharedFinish(button,name,"value");
          return button;
      function _odFileCommon(label,name,path,prompt,extension) {
          var buttonWidth = 80;
          var buttonBox = [controlBox.left,controlBox.top,controlBox.left + buttonWidth,controlBox.bottom];
          var nameBox = [controlBox.left + buttonWidth + 10,controlBox.top,D_DIALOG_WIDTH,controlBox.bottom];
          var f = new File(path);
          var nameCtl = oD.add('statictext',nameBox);
          var button = oD.add('button',buttonBox,'...');
          button.nameCtl = nameCtl;
          nameCtl.text = f.name;
          button.value = f.fsName;
          button.file = f;
          button.filePrompt = prompt;
          button.fileExtension = extension;
          return button;
      function _odOpenFile(label,name,path,prompt,extension) {
          oD = this;
          var buttonCtl = _odFileCommon(label,name,path,prompt,extension);
          buttonCtl.onClick = function(){
              var f = this.file.openDlg(this.filePrompt);
              if(f) {
                  this.file = f;
                  this.value = f.fsName;
                  this.nameCtl.text = f.name;
          return buttonCtl;
      function _odSaveFile(label,name,path,prompt,extension) {
          oD = this;
              var f = this.file.saveDlg(this.filePrompt);
              if(f) {
                  this.file = f;
          return buttonCtl;
      function _odSelectFolder(label,name,path,prompt,extension) {
          oD = this;
          buttonCtl.folder = new Folder(path);
          buttonCtl.nameCtl.text += "/";
              var f = this.folder.selectDlg(this.filePrompt);
              if(f) {
                  this.folder = f;
                  this.nameCtl.text = f.name + "/";
          return buttonCtl;
      function _odCheckbox(label,name,value,checkboxText) {
              oD = this;
              var control = oD.add('checkbox',controlBox,checkboxText);
              oD._odControlSharedFinish(control,name,"value");
              return control;
      function _odRadioButtons(label,name,value,radioChoices) {
          var oD = this;
          controlBox = oD ._odControlShared(label,name);
          var itemHeight = controlBox.bottom - controlBox.top;
          result = oD.add('edittext',controlBox,value);
          result.onChange = function(){
              var i;
              for(i = 0; i < this.buttons.length; i++) {
                  var button = this.buttons[i];
                  button.value = (button.theChoice == this.text);
          result.hide();
          result.value = value;
          result.buttons = new Array();
          var i;
          for(i = 0; i < radioChoices.length; i++) {
              var choice = radioChoices[i];
              if(i > 0) {
                  var bump = itemHeight + D_MARGIN;
                  controlBox.top += bump;
                  controlBox.bottom += bump;
                  oD.curYPos += bump;
              var rb = oD .add('radiobutton',controlBox,choice);
              rb.value = choice == value;
              rb.theChoice = choice;
              rb.theGroupErsatzControl = result;
              rb.onClick = function(){this.theGroupErsatzControl.value = this.theChoice;};
              result.buttons[result.buttons.length] = rb;
          oD._odControlSharedFinish(result,name,"text");
          return result;
      function _odMenu(label,name,value,menuChoices) {
          var oD = this;
          var control = oD.add('dropdownlist',controlBox,menuChoices);
          control.menuChoices = menuChoices;
          var index = 0;
          for(var i = 0; i < menuChoices.length; i++) {
              if(value == menuChoices[i])
                  index = i;
          control.selection = index;
          control.onChange = function() {
              this.value = this.selection.text;
              } // make them all .value accessible
      function _odSectionLabel(label) {
          var oD = this;
          var b2 = new Object();
          b2.left = D_MARGIN;
          b2.top = oD.curYPos;
          b2.right = b2.left + D_DIALOG_WIDTH;
          b2.bottom = b2.top + D_CONTROLHEIGHT;
          oD.curYPos += D_CONTROLHEIGHT + D_MARGIN;
          oD.add('statictext',b2,label + ':',{multiline:true});
      function _odBoxedText(lines,text) {
          var oD = this;
          var width = D_DIALOG_WIDTH;
          var height = lines * 16;
          var b = new Object();
          b.top = oD.curYPos;
          b.bottom = b.top + height + 2 * D_MARGIN;
          b.left = D_MARGIN;
          b.right = b.left + width;
          oD.curYPos = b.bottom + D_MARGIN;
          var panel = oD.add('panel',b);
          b2.left = D_MARGIN;
          b2.top = D_MARGIN;
          b2.right = b2.left + width - 2 * D_MARGIN;
          b2.bottom = b2.top + height;
          panel.add('statictext',b2,text,{multiline:true});
      function _odSeparator() {
          var oD = this;
          var height = oD.groupGap;
          var barWidth = oD.ominoDialogWidth;
          if(barWidth) {
              b.top = oD.curYPos + height / 2;
              b.bottom = b.top;
              b.left = D_MARGIN;
              b.right = b.left + barWidth;
              var barHeight = 2;
              b.top -= barHeight / 2;
              b.bottom = b.top + barHeight;
              oD.add('panel',b);
          oD.curYPos += height;
      function _odAppendGap() {
          oD = this;
          oD.curYPos += oD.groupGap;
      function appendOKCancel(dialog) {
          var cancelRect = new Object();
          var okRect = new Object();
          cancelRect.left = D_MARGIN
          cancelRect.top = y;
          cancelRect.right = cancelRect.left + D_BUTTONWIDTH;
          cancelRect.bottom = cancelRect.top + D_CONTROLHEIGHT;
          okRect.left = cancelRect.right + D_MARGIN + D_MARGIN;
          okRect.top = y;
          okRect.right = okRect.left + D_BUTTONWIDTH;
          okRect.bottom = okRect.top + D_CONTROLHEIGHT;
          var cancelBtn = dialog.add('button',cancelRect,'Cancel',{name:'cancel'});
          var okBtn = dialog.add('button',okRect,'OK',{name:'ok'});
          cancelBtn.theDialog = dialog;
          cancelBtn.onClick = function(){this.theDialog.close(0);};
          okBtn.theDialog = dialog;
          okBtn.onClick = function(){this.theDialog.close(1);};
          dialog.curYPos = okRect.bottom + D_MARGIN;
      function trimDialogBounds(dialog) {
          var xMax = 20;
          var yMax = 20;
          var n = dialog.children.length;
          var i;
          for(i = 0; i < n; i++) {
              var aChild= dialog.children[i];
              var aChildBounds = aChild.bounds;
              if(aChildBounds.right > xMax)
                  xMax = aChildBounds.right;
              if(aChildBounds.bottom > yMax)
                  yMax = aChildBounds.bottom;
          dialog.bounds.right = dialog.bounds.left + xMax + D_MARGIN;
          dialog.bounds.bottom = dialog.bounds.top + yMax + D_MARGIN;
          dialog.bounds.bottom = dialog.curYPos + dialog.bounds.top;
      function newOminoDialog(name) {
          var oD = new Window('dialog',name,[100,100,500,500]);
          oD.curYPos = 20;
          oD.groupGap = 12;
          oD.itemNames = new Array();
          oD.item
          oD.items = new Array();
          oD.itemValueFieldNames = new Object();
          oD.ominoDialogWidth = D_DIALOG_WIDTH;
          oD.gap = _odAppendGap;
          oD.number = _odNumber;
          oD.string = _odText;
          oD.radioButtons = _odRadioButtons;
          oD.checkbox = _odCheckbox;
          oD.sectionLabel = _odSectionLabel;
          oD.separator = _odSeparator;
          oD.boxedText = _odBoxedText;
          oD.color = _odColor;
          oD.openFile = _odOpenFile;
          oD.selectFolder = _odSelectFolder;
          oD.saveFile = _odSaveFile;
          oD.menu = _odMenu;
          oD.set = _odSet;
          oD.run = _odRun;
          oD.get = _odGet;    oD._odControlShared = _odControlShared;
          oD._odControlSharedFinish = _odControlSharedFinish;
          return oD;
      function _odGet() {
          var values = new Object();
          var name;
          for(name in this.items) {
              var value = this.items[name].value;
              values[name] = value;
          return values;
      function _odSet(values) {
          var oD = this;
          if(!values)
              return;
          for(var p in values) {
              var value = values[p];
              var item = oD.items[p];
              if(!item)
                  continue;
              var itemValueFieldName = oD.itemValueFieldNames[p];
              if(!itemValueFieldName)
                  continue;
              item[itemValueFieldName] = value;
              item.notify('onChange');
      function _odRun() {
          var oD = this;
          if(!oD.finishingTouches) {
              oD.separator(oD);
              oD.gap();
              appendOKCancel(oD);
              oD.gap();
              trimDialogBounds(oD);
              oD.finishingTouches = true;
          var resultCode = oD.show();
          if(resultCode != 1)
              return null;
          var result = oD.get();
          return result;
          var sortProp             = "top";
          var doc                     = app.activeDocument;
          var sel                      = doc.selection;
          var tfs                      = new Array();
          var separator             = "[><]";
          var fitToContent        = false;
          var fitToSelection     = false;
          var minversion        = 5; //for dialog to run
          var version                = parseInt(app.version.split(".").shift());
          var coordTop            = new Array();
          var coordBottom     = new Array();
          var coordRight        = new Array();
          var coordLeft            = new Array();
          var applyTo             = "selected frames";
          var defaultIgnoreLocked = true;
          var ignoreLocked     = defaultIgnoreLocked;
      init();
      function init(){
          if(version >= minversion) runDialog();
          else run();
      function run(){
          if(applyTo == "selected frames") {
                  tfs = collectFields(sel);
                  if (tfs.length == 1) {
                      alert("You must select more than one textframe.");
                      return;
                  } else if (tfs.length < 1) {
                      alert("No textframes selected.");
                      return;
                  } else {
                      tfs = tfs.sort(sortFields);
                      assemble(tfs);
          } else if(applyTo == "current page") {
                  tfs = collectFields(app.activeWindow.activePage.textFrames);
                      alert("The current page only has one textframe.");
                      return;
                      alert("The current page does not have any textframes.");
                      return;
                  } else {
                      assemble(tfs);
          } else if(applyTo == "all pages") {
                  var storedPage = app.activeWindow.activePage;
                  for(var i=0; i < doc.pages.count(); i++){
                      app.activeWindow.activePage = doc.pages.item(i);
                      tfs = collectFields(doc.pages.item(i).textFrames);
                      assemble(tfs);
              app.activeWindow.activePage = storedPage;
      function runDialog()
          var omd = newOminoDialog("Merge Textframes");
          omd.menu("Apply to","applyto","selected frames",["selected frames",
          "current page", "all pages"]);
          omd.separator();
          omd.checkbox("Ignore locked layers", "ignorelocked", defaultIgnoreLocked , "(applies to pages)");
          omd.separator();
          omd.radioButtons("Sort by","sort","top",["top","left","bottom","right"]);
          omd.separator();
          omd.string("Separator","separator","");
          omd.boxedText(3,"\\r = hard return, \\n = soft return, \\t = tab \n\nUse hard return(s) if you want to preserve paragraphs styles");
          omd.separator();
          omd.checkbox("Fit Frame to", "afit", fitToContent , "merged content");
          omd.checkbox("", "sfit", fitToSelection , "selection size");
          var result = omd.run();
          if(result != null) {
              separator = result.separator;
              separator = replace(separator, "\\r", "\r");
              separator = replace(separator, "\\t", "\t");
              separator = replace(separator, "\\n", "\n");
              sortProp  = result.sort;
              fitToContent  = result.afit;
              fitToSelection = result.sfit;
              applyTo = result.applyto;
              ignoreLocked = result.ignorelocked;
              run();
      function collectFields(selArr) {
          var tArr = new Array();
          selArr = (ignoreLocked) ? getUnlockedLayerItems(selArr) : selArr;
          for(var i=0; i < selArr.length; i++){
              var t = selArr[i];
              if (t == undefined) continue;
              if(t.constructor.name == "TextFrame"){
                  tArr.push(t);
                  var bounds = t.geometricBounds;
                  coordTop.push(bounds[0]);
                  coordLeft.push(bounds[1]);
                  coordBottom.push(bounds[2]);
                  coordRight.push(bounds[3]);
          return tArr;
      function getUnlockedLayerItems(inArr) {
          var outArr = new Array();
          for(var i=0; i < inArr.length; i++){
              if(!inArr[i].itemLayer.locked) outArr.push(inArr[i]);
          return outArr;
      function assemble(inArr){
          var arr = inArr;
          var targFrame = arr[0];
          for (var i=arr.length-1; i > 0; i--){
              var storedLayer = arr[i].itemLayer;
              var storedLayerLock = storedLayer.locked;
              if(separator.length > 0)  {
                  arr[i-1].textStyleRanges.lastItem().contents += separator;
              arr[i].previousTextFrame = arr[i-1];
              arr[i].itemLayer.locked = false;
              arr[i].locked = false;
              arr[i].remove();
              storedLayer.locked = storedLayerLock;
          targFrame.nextTextFrame = null;
          if(fitToSelection) {
              var selectionBounds = new Array();
              var offsetBounds = [0, 0, 0, 0];
              if(app.activeWindow.activePage.side == PageSideOptions.RIGHT_HAND && applyTo == "all pages") {
                  offsetBounds = app.activeWindow.activePage.bounds;
              selectionBounds[0] = coordTop.sort(sortNumbers).shift();
              selectionBounds[1] = coordLeft.sort(sortNumbers).shift() + offsetBounds[3] - offsetBounds[1];
              selectionBounds[2] = coordBottom.sort(sortNumbers).pop();
              selectionBounds[3] = coordRight.sort(sortNumbers).pop();
              targFrame.geometricBounds = selectionBounds;
          if(fitToContent) {
              targFrame.fit(FitOptions.FRAME_TO_CONTENT);
      function sortNumbers(a,b){
              return a-b;
      function sortFields(a,b) {
          var tProp = sortProp;
          var aN = getCoordinateValue(a, tProp);
          var bN = getCoordinateValue(b, tProp);
          var returnVal = aN - bN;
          if(returnVal == 0) {
              if(tProp == "top" || tProp == "bottom") tProp = "left";
              else if(tProp == "left" || tProp == "right") tProp = "top";
          if(tProp == "right" || tProp == "bottom") returnVal *= -1;
          return returnVal;
      function getCoordinateValue(obj, type) {
          var returnVal;
          var bounds = obj.geometricBounds;
              switch(type){
                      case "left":
                          returnVal = bounds[1];
                          break;
                      case "top":
                          returnVal = bounds[0];
                          break;
                      case "right":
                          returnVal = bounds[3];
                          break;
                      case "bottom":
                          returnVal = bounds[2];
                          break;
          return returnVal;
      function replace(searchStr, findStr, replaceStr){
          var tArr = searchStr.split(findStr);
          var returnStr = tArr.join(replaceStr);
          return returnStr;
      VK
