22 Replies Latest reply on Jul 27, 2014 5:32 AM by Teetan VK
    How can I find-change only in the master pages?
    Teetan VK Level 1
      Hi, everyone
      for instance:
      I want to change 2013 to 2014 but only in the master pages.
      in all the opening files' master pages.
      How can I do that?
      Teetan
        • 1. Re: How can I find-change only in the master pages?
          Jump_Over Level 5
          First use find(), after this filter results and finally change those one you need to.
          There is no direct option.
          Jarek
          • 2. Re: How can I find-change only in the master pages?
            Teetan VK Level 1
            Thank you jarek
            I will use synchronize in a book
            Teetan
            • 3. Re: Re: How can I find-change only in the master pages?
              Kai Rübsamen Adobe Community Professional
              I would do it in this way:
              // Your settings
              var SEARCH_PATTERN = '2013';
              var CHANGE_PATTERN = '2014';
              // Set SEARCH
              app.findTextPreferences = app.changeTextPreferences = null;
              app.findChangeTextOptions.includeMasterPages = true;
              app.findTextPreferences.findWhat = SEARCH_PATTERN;
              app.changeTextPreferences.changeTo = CHANGE_PATTERN;
              // Variables
              var allDocs = app.documents,
                  nDocs = allDocs.length,
                  nFounds = [],
                  counter = 0;
              // SEARCH ONLY MASTERPAGES IN ALL OPEN DOCS
              for ( var i = 0; i < nDocs; i++ ) {
                  var curDoc = app.documents[i],
                  mPages = curDoc.masterSpreads.everyItem().pages.itemByRange(0, -1),
                  target = mPages.textFrames.everyItem().paragraphs.everyItem();
                  target.changeText();
                  nFounds.push(target.changeText().length);
              for ( var i = 0; i < nFounds.length; i ++ ) {
                  counter = counter + nFounds[i];
              alert( counter + " expressions have been changed." );
              – Kai
              • 4. Re: How can I find-change only in the master pages?
                Jump_Over Level 5
                I was to quick with my 1st answer, Kai is right.
                changeText() method can be used with various targets. So if you prepare a target first - there is a direct option.
                Jarek
                • 5. Re: How can I find-change only in the master pages?
                  Teetan VK Level 1
                  Hi, Jarek and Kai
                  I try the write script by my self like this but not work:
                  app.doScript('main()', ScriptLanguage.JAVASCRIPT, undefined, UndoModes.FAST_ENTIRE_SCRIPT, "Indent Paragraphs");
                  function main(){
                  var _selection = app.selection[0];
                  for ( i = 1; i < app.documents.length; i++) {
                    myDoc = app.documents[i];
                  app.findGrepPreferences = changeGrepPreferences = null;
                  app.findGrepPreferences.findWhat = "\\b20+\\b";
                  var found = app.selection[0].findGrep();
                  for(var f=0;f<found.length;f++)
                          app.findGrepPreferences.findWhat = "\\d+";
                          var foundnum = found[f].findGrep();
                          var newnum = parseInt(foundnum[0].contents) + 1;
                          app.changeGrepPreferences.changeTo = newnum.toString();
                          found[f].changeGrep();
                  how can fix it?
                  • 6. Re: Re: How can I find-change only in the master pages?
                    I realize, that here is no need for itemByRange.
                    So the target line could be writen shorter (no itemByRange needed):
                    target = curDoc.masterSpreads.everyItem().pages.everyItem().textFrames.everyItem();
                    – Kai
                    • 7. Re: How can I find-change only in the master pages?
                      Teetan VK Level 1
                      How can I combine the two scripts idea into one?
                      Teetan
                      • 8. Re: How can I find-change only in the master pages?
                        Jump_Over Level 5
                        @Teetan
                        Which numbers are you going to grow?
                        - each found on master pages
                        - only the one started with "20"
                        - is it posible to match a number 2099 there?
                        Jarek
                        • 9. Re: How can I find-change only in the master pages?
                          Teetan VK Level 1
                          Hi, I try again
                          changed it into this:
                          but not error
                          app.doScript('main()', ScriptLanguage.JAVASCRIPT, undefined, UndoModes.FAST_ENTIRE_SCRIPT, "Find-change num");
                          function main(){
                          for(var i=0;i<found.length;i++)
                                  found[i].changeGrep();
                          Teetan
                          • 10. Re: How can I find-change only in the master pages?
                            Teetan VK Level 1
                            Hi, Jarek and Kai
                            what I want to change has growing requested, and I wish it has an undo possible.
                            thank you
                            Teetan
                            • 11. Re: How can I find-change only in the master pages?
                              Teetan VK Level 1
                              Hi
                              Jarek
                              may be 2099
                              Teetan
                              • 12. Re: Re: How can I find-change only in the master pages?
                                I changed my current version in the meantime a bit, since the counter did show the wrong results, if you start the script a second time.
                                // Your settings
                                // Set SEARCH
                                // Variables
                                    nFounds = [],
                                    counter = 0;
                                    var allFounds = target.changeText();
                                    for (var n = 0; n < allFounds.length; n ++) {
                                        var curFound = allFounds[n];
                                        if (curFound.length != 0) {
                                            counter += curFound.length;
                                Teetan, I have no idea what you try to do with your second script. Please provide clear steps (1,2,3) and maybe a screenshot before / after.
                                And: Realize that 'undo' is available only per document. So if you have 20 docs open, you must undo in every document, even if we spent a doScript-Function!
                                • 13. Re: How can I find-change only in the master pages?
                                  Teetan VK Level 1
                                  Kai
                                  sorry I confuse you in some way
                                  now I clarify it
                                  1)  I want to find-change the digit only in all the opening files' master
                                  2)  the digit has growing requested by years, I mean this year I find 2013 change to 2014 and next year I have to chan 2014 change to 2015
                                  and finally I wish the script has UndoModes.ENTIRE_SCRIPT function
                                  Regard
                                  Teetan
                                  • 14. Re: How can I find-change only in the master pages?
                                    Teetan VK Level 1
                                    Hi Kai
                                    this script can find digit then change +1
                                    function main(){
                                    app.findGrepPreferences.findWhat = "aged \\d+";
                                            var foundnum = found[i].findGrep();
                                    I get this idea, but I want it only work on master pages
                                    Regard
                                    Teetan
                                    • 15. Re: How can I find-change only in the master pages?
                                      Teetan VK Level 1
                                      Hi Kai
                                      can you help correct this script:
                                              app.doScript('main()', ScriptLanguage.JAVASCRIPT , [], UndoModes.ENTIRE_SCRIPT, "Find-change digit" );
                                      function main(){
                                      // Set SEARCH
                                      app.findTextPreferences.findWhat = "2017";
                                      app.changeTextPreferences.changeTo = "2018";
                                      app.findTextPreferences.findWhat = "2015";
                                      app.changeTextPreferences.changeTo = "2016";
                                      app.findTextPreferences.findWhat = "2014";
                                      app.changeTextPreferences.changeTo = "2015";
                                      app.findTextPreferences.findWhat = "2013";
                                      app.changeTextPreferences.changeTo = "2014";
                                      // Variables
                                          nFounds = [],
                                          counter = 0;
                                      Teetan
                                      • 16. Re: Re: How can I find-change only in the master pages?
                                        Jump_Over Level 5
                                        Hi Teetan,
                                        To define a goal is more than half way of creating script.
                                        Check this:
                                        app.doScript('main()', ScriptLanguage.JAVASCRIPT, undefined, UndoModes.FAST_ENTIRE_SCRIPT, "grow numbers on masters");
                                        function main() {
                                          catchOption = app.findChangeGrepOptions.includeMasterPages;
                                          app.findChangeGrepOptions.includeMasterPages = true;
                                          app.findGrepPreferences.findWhat = "\\b\\d+\\b";
                                        var
                                          mTarget = app.documents.everyItem().masterSpreads.everyItem().textFrames.everyItem(),
                                          mFound = mTarget.findGrep(),
                                          mConFound = [],
                                          len = mFound.length;
                                          if (len && mFound[0].constructor.name == "Array")
                                               while (len-->0)
                                                    mConFound = mConFound.concat(mFound[len]);
                                          len = mConFound.length;
                                          while (len-->0) {
                                               mConFound[len].contents = String(Number(mConFound[len].contents) + 1);
                                          app.findChangeGrepOptions.includeMasterPages = catchOption;
                                        Jarek
                                        • 17. Re: How can I find-change only in the master pages?
                                          Teetan VK Level 1
                                          Hi Jreak,
                                          it's what I want
                                          thank you so much
                                          appreciate
                                          Teetan
                                          • 18. Re: How can I find-change only in the master pages?
                                            Teetan VK Level 1
                                            Hi Jreak
                                            Can you tell me
                                            this script can only work on:
                                            function main(){
                                            // Set SEARCH
                                            app.findTextPreferences = app.changeTextPreferences = null;    // only work on this part
                                            app.findChangeTextOptions.includeMasterPages = true;           // the rest are unfunction
                                            app.findTextPreferences.findWhat = "2013";                            // can you tell me why?
                                            app.changeTextPreferences.changeTo = "2014";                     //  can you make it happen, in case of find something not a digit
                                            // Variables
                                                nFounds = [],
                                                counter = 0;
                                            regard
                                            Teetan
                                            • 19. Re: Re: How can I find-change only in the master pages?
                                              Jarek, your version ist much shorter, than my script, great
                                              I have this in the meantime:
                                              if ( app.documents.length > 0 ) {
                                                  if ( app.scriptPreferences.version >= 6 ) {
                                                      app.doScript( main, ScriptLanguage.JAVASCRIPT , [], UndoModes.ENTIRE_SCRIPT, "Search in Masterpages" );
                                                  else {
                                                      main();
                                              } else {
                                                  alert ( "No documents open!" );
                                              function main() {
                                                  // Your settings
                                                  var SEARCH_PATTERN = '\\b201[4-6]\\b';
                                                  // Set SEARCH
                                                  app.findGrepPreferences = app.changeGrepPreferences = null;
                                                  app.findGrepPreferences.findWhat = SEARCH_PATTERN;
                                                  // Variables
                                                      nFounds = [],
                                                      counter = 0;
                                                      var allFounds = target.findGrep();
                                                      for ( var n = 0; n < allFounds.length; n ++ ) {
                                                          var framesFound = allFounds[n];
                                                          if ( framesFound.length > 0 ) {
                                                               for ( var j = framesFound.length-1; j >= 0 ; j-- ) {
        var curFound = framesFound[j];
        var newNumber = (parseInt( curFound.contents) +1).toString();
        curFound.contents = newNumber;
                                                              } // for
                                                          counter += framesFound.length;
                                                          } // if
                                                      } // for
                                                  } // for
                                              } // main
                                              • 20. Re: How can I find-change only in the master pages?
                                                Teetan VK Level 1
                                                Hi, Kai
                                                what if find-change something not a digit, but only in master?
                                                Teetan
                                                • 21. Re: Re: How can I find-change only in the master pages?
                                                  Teetan, first of all, after Jareks code, I correct my version a bit. Nevertheless my version is a bit longer than Jareks, because I check some things more, have a alert at the end and I’m not able to write such short scripts as Jarek (as a advanced beginner I have always problems with while loops …).
                                                  The trick ist the line nr. 16 SEARCH_Pattern. Here you can enter the right expression. E.g. if you want to find 2013 - 2016 change [4-6] to [3-6]. However: The script assumes, that you want to grow up numbers +1. So if you want to change other things on the masterpages, all those scripts from today won’t work and must be modified > new goals >> new scripts ;-)
                                                      else {
                                                          main();
                                                  } else {
                                                  function main() {
                                                      // Your settings
                                                      var target = app.documents.everyItem().masterSpreads.everyItem().textFrames.everyItem();
                                                      var counter = 0;
        curFound.contents = String( Number( curFound.contents) + 1 );
                                                          } // if
                                                      } // for
                                                  } // main
                                                  but not today. Sunny wheather. Let’s go outside .
