1 Reply Latest reply on Aug 16, 2014 7:00 AM by daviddoria
    Save multiple HDR versions without re-aligning
    daviddoria
      In Lightroom, I will select several images (an exposure bracket) and select Edit In -> Photoshop HDR Pro. It will take a few minutes, and then I can play with the HDR options and close the wizard which gives me a new photoshop layer that is the HDR image. I find myself often wanting to export the 32-bit version, as well as export a version that has an HDR compression applied. To do this, I have to repeat the entire process twice, which takes quite a bit of time. Is there anyway I can save out these two different versions without starting all the way back in Lightroom the second time?
      David
