3 Replies Latest reply on Jul 28, 2014 6:36 PM by A.T. Romano
    File Import Problems
    john martin Level 1
      I am currently trying to make a short one minute clip and have repeatedly imported files into the Premier 11 video editor.
      The trouble I am having is the files appear of very low quality. When I open the same file in the Organizer they look perfect.
      Even when I do a slide show in Organizer they appear perfect. However, when I transfer them to Video Editor and place them in the time line they appear of very poor quality. I have tried both smart fix and render with no success.
      Any suggestions would be greatly appreciated.
      As a backup plan can I use the slide show and add audio and then save the file to my hard drive so I can write it to disk. I am needing ultimately to make a dvd and mail it to a customer.
      Thanks for any help you can provide.
      I am using windows 7
      John Martin
      [Title edited for clarity... Mod]
      [personal information removed... Mod - https://forums.adobe.com/docs/DOC-3731]
      [This is an open forum, not Adobe support, please do not post personal information]
      [If you are posting using email, please turn your 'sig file' function OFF for posting]
        • 1. Re: File Import Problems
          A.T. Romano Level 7
          John Martin
          Premiere Elements 11 on Windows 7 64 bit....
          What are the properties of this 1 minute clip (or the properties of a bunch of clips that you plan to export as a 1 minute file).
          Video compression
          Audio compression
          Frame Size
          Frame Rate
          Interlaced or Progressive
          File extension
          Pixel Aspect Ratio
          and/or what is the brand/model/settings for the camera that regarded the clip? I am assuming that the clip is video rather than still. Is that correct?
          What are you setting as the project preset to match the properties of the source video? Or, are you letting the project take charge of project settings?
          To determine what project preset is being set for the project, please tell us the readings under Edit Menu/Project Settings/General (Editing mode, Timebase, Frame Size, and Pixel Aspect Ratio even if the fields look grayed out.)
          Forget about the Elements Organizer 12 and let us focus on quality on your file as an import into a new Premiere Elements 12 project with the best project preset possible and good quality in the rendered Timeline when viewed in the Edit area monitor.
          Let us start here and put the basic information together to see what we have. All sort of scenarios possible.
          Where is all this going...
          DVD-VIDEO standard or widescreen on DVD disc
          AVCHD format on DVD disc
          Blu-ray disc format on Blu-ray disc
          Thanks.
          ATR
          • 2. Re: File Import Problems
            john martin Level 1
            ATR
            I will try my best to answer your questions. I have added
            still only up to this point. I am going to video a short clip tomorrow and add
            it to the very first part of the clip as an introduction.
            The settings you asked for are as follows:
            Editing Mode grayed out as HD 1080i
            Timebase grayed out as 29.97 frames/second
            Video    Frame Size          1920       horizontal            1080       vertical
            Pixel Aspect Ratio: grayed out Square Pixels (1.0)
            Fields  grayed out
            Upper Field First
            Display Format  30ffps
            Drop-Frame Timecode
            Title Safe area   20           % horizontal`      20 `         % vertical
            Action Safe Area              10           %horizontal        10           %vertical
            Audio
            Sample Rate       grayed
            out          48000 Hz
            Display Format  Audio
            Samples
            With your help I tried to change the capture rate from HDV
            to DV and it made a big difference in clarity on my stills
            Lastly I burned the disk to AVCHD and got the best
            reproduction.
            Again, your help has been invaluable.
            In your debt and thanks
            John  Martin
            • 3. Re: File Import Problems
              A.T. Romano Level 7
              john martin
              Just some guidelines to explore...
              The project preset should match the properties of your source media. This is especially important.
              You cannot change project settings once set. (A longer story contradicts that a bit, but) No significant Project Settings changes can be made in Edit Menu/Project Settings/General. That is a place to confirm settings rather than to establish settings.
              If you have an all stills situation and a DVD-VIDEO destination, I have found that you get the best results with photos 1920 x 1080 and using the project preset of NTSC DSLR 1080p DSLR 1080p30@ 29.97. The end result seems to be sharper than from other routes.
              If you have video recorded at 1440 x 1080 HD Anamorphic 16:9, then use the project preset for the NTSC AVCHD HD1080p30. But, when it comes to export in a like format, use the export presets with the 1920 x 1080 specifications. All this has to do with trying to avoid player problems trying to read the 16:9 flag in the 1440 x 1080 HD Anamorphic 16:9. Both of these formats give the same 1920 x 1080 display. But, to get there, the 1440 x 1080 has to be stretched by the 16:9 flag to 1920 x 1080.
              Also remember that when you import a source file into Premiere Elements, a copy of the file automatically get copied to the Elements Organizer. This is probably the better route to get videos into the Elements Organizer than importing them into the Elements Organizer and then into Premiere Elements  with the Elements Organizer command Edit With Premiere Elements Editor?
              Please recap, indicating where you are in your path to completion of your goal...where we are and where we need to be.
              Thanks.
              ATR
