8 Replies Latest reply on May 1, 2007 10:39 AM by Chrpil
    Graphics Disappear
    Chrpil
      We are on RoboHelp version HTML X 5.0.2. I recently was upgraded to a new computer, and when I convert now from RoboHelp to Word, our graphics disappear. The first instance of a repeated graphic displays, has a little whilte box after it, and then never shows up again. I've tried reimporting the graphic, and this still doesn't work. I've compared my settings for generating a print document with a co-worker who is not having this problem, and they are the same. My co-worker has checked out my project and tried the conversion on her computer, and surprise, her graphics show up! What settings can I check? I've already rebooted my computer. Will this required reinstalling Word? Thanks, Chrpil
        • 1. Re: Graphics Disappear
          Welcome to the forum.
          Have we already discussed this one?
          Are you both running the project locally and generating locally?
          • 2. Re: Graphics Disappear
            Chrpil Level 1
            You did, but the solution of going to the folder and changing the settings there did not work, alas. I am running locally and generating locally. Thanks!
            • 3. Re: Graphics Disappear
              Can you point me to the other thread so that I can see exactly what has been covered? You must have created it under another name as this thread shows two posts which are both in this thread.
              Creating another thread does not help. If the first answer does not work, please go back to the thread and say what went wrong. Then I or others can suggest other things.
              • 4. Re: Graphics Disappear
                Chrpil Level 1
                The other thread is….
                http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=65&catid=448&threadid =1166099&highlight_key=y&keyword1=graphic
                Also known as
                Topic Title: Missing Graphics
                Topic Summary: Missing graphics in Robohelp X5 trial
                Created on: 06/23/06
                Sorry about not continuing the original thread. I figured, the original poster never responded back to indicate whether the suggestions worked. Figured it was a dead thread. I’ve now posted to that thread my original question. It’s all new to me, this process. : )
                Regards,
                Chrpil
                • 5. Re: Graphics Disappear
                  No I meant was it something WE had discussed. I was also thinking recently.
                  Take a look at this post.
                  http://tinyurl.com/2rhzvd
                  • 6. Re: Graphics Disappear
                    Chrpil Level 1
                    We, as in you and I? No, I don't think so. This is my first time posting. I did see that other thread you mentioned, and I reviewed that one. I think my issue is a little different because my images are visible in RH, but not in the word document I'm trying to create. I went to Word and found View > Picture, but could not find a selection called "placeholders." I can insert the graphic using View > Picture > Insert Picture, but it defeats the purpose if I have to insert my graphics by hand, alas.
                    • 7. Re: Graphics Disappear
                      OK. Take a look at Print Issues on my site. I am not sure why you are having issues with the same project if you both have the same versions of Word but take a look at that topic next.
                      • 8. Re: Graphics Disappear
                        Chrpil Level 1
                        Wow! Thanks. I think this worked:(this is what I found, for the next person who searches on this issue)
                        "Then Eileen Suszek came up with this neat idea.
                        1. Create the document in RoboHelp and choose the "Link to Document" check box.
                        2. In Word click Edit | Links.
                        3. In the dialog select all the files.
                        3. Tick the "Save pictures in Document" check box.
                        4. Click OK. "
                        Basically, I changed the settings in RH on the Print Document General - Printed Documentation window. I have PDF'd the project and am sending it to be reviewed, to make sure it looks good on someone else's computer.
                        Regards,
                        Chrpil
