This content has been marked as final.
Show 3 replies
1. Re: Can I convert or copy a paintbrush path to a pen path?
Silkrooster Jul 27, 2014 9:21 PM (in response to Stephen Pickering122)All you should need to do is set the fill and stroke to none. You would then have a single path with no thickness.
2. Re: Can I convert or copy a paintbrush path to a pen path?
Stephen Pickering122 Jul 27, 2014 10:03 PM (in response to Silkrooster)Thank you Silkrooster. Having both variables set to "none" allows it to be copy and pasted in AI but it cannot be pasted in AE. However, if I set the thickness to .5 it is still an outline but is very thin, which works as needed in this case. Thanks for the work around, it gets the job done!
It would be awesome if there was a way to convert them for future reference as this won't always work, but it works just fine for this.Thanks for your help!
-Stephen
3. Re: Can I convert or copy a paintbrush path to a pen path?
Silkrooster Jul 28, 2014 10:49 PM (in response to Stephen Pickering122)You're welcome.
