3 Replies Latest reply on Jul 29, 2014 3:11 AM by Nipun Asthana
    Flash pro cc xul controlls jsfl need help
    Svolash
      Hello all
      i had used flash cs for a while and was using lots of downloaded jsfl commands that would help me speed up work
      Switched to cc lately and those commands do not work
      heres a code of one of not working commands.
      dialog buttons="accept, cancel" title="Search and Replace v1.0">
      <grid>
      <columns>
          <column />
          <column />
      </columns>
      <rows>
          <row>
          <label control="searchFor" value="Search For:" />
              <textbox id="searchFor" value="" />
          </row>
          <row>
          <label control="replaceWith" value="Replace With:" />
              <textbox id="replaceWith" value="" />
          </row>
          <spacer />
              <radiogroup id="searchType"/>
                  <radio label="Search All Items" selected = "true" />
                  <radio label="Search Selected Items" />
              </radiogroup>
      </grid>
      </dialog>
      Could you tell me what to modify so i can run this command under CC
      Thanks in advance
        • 1. Re: Flash pro cc xul controlls jsfl need help
          Svolash Level 1
          sorry that was only the xml window code for the command
          the real code for the command is this:
          var doc = fl.getDocumentDOM();
          var lib = doc.library;
          var allItems = lib.items;
          var selItems = lib.getSelectedItems();
          var searchItems;
          var nameList
          var oldname;
          var newname;
          var xml = doc.xmlPanel(fl.configURI + "XULControls/SearchReplace.xml");
          if(xml.dismiss == 'accept'){
              var searchFor = xml.searchFor;
              var replaceWith = xml.replaceWith;
              if(xml.searchType == "Search Selected Items"){
                  searchItems = selItems;
                  nameList = removePath(true);
              }else{
                  searchItems = allItems;
                  nameList = removePath(false);
              if(searchItems.length == 0){
                  alert("No Library items selected");
              }else{
                  for(i = 0; i < searchItems.length; i++){
                      oldname = nameList[i];
                      newname = oldname.replace(searchFor, replaceWith);
                      searchItems[i].name = newname;
          function removePath(bSelItems){
              if(bSelItems){
                  libSelPath=fl.getDocumentDOM().library.getSelectedItems();
              }else{
                  libSelPath=fl.getDocumentDOM().library.items;
              itemNames = new Array();
              for (a = 0; a < libSelPath.length; a++){
                  charStart = libSelPath[a].name.lastIndexOf("/") + 1;
                  itemNames[a] = libSelPath[a].name.substring(charStart);
              return itemNames;
          thx
          • 2. Re: Flash pro cc xul controlls jsfl need help
            Svolash Level 1
            after some digging in the code i realized that the error here is in the xml file that the command is pointing at.
            actually the error is in the way columns are represented, after i deleted the columns lines the tool came back to life, warped but not too bad
            Does anybody here know how to recode the columns property?
            • 3. Re: Flash pro cc xul controlls jsfl need help
              Nipun Asthana Adobe Employee
              The arrangement seems to be a little incorrect.
              </rows> is missing and </grid> looks to be misplaced.
              You should put both these closing tags just after the last </row> tag (above the <spacer /> tag).
              <dialog buttons="accept, cancel" title="Search and Replace v1.0">
              <grid>
              <columns>
                  <column />
                  <column />
              </columns>
              <rows>
                  <row>
                  </row>
                  <row>
                  </row>
              </rows>
              </grid>
                  <spacer />
                      </radiogroup>
              </dialog>
