5 Replies Latest reply on Jul 28, 2014 4:59 AM by Teetan VK
    Remove space in cells.
    Dapeamel Level 1
      Hello guys,
      i got this problem.
      when we recieve indd files from our customers,
      there are sometimes a space first in each cell then comes a number in tables and sometimes there are no space.
      see examples below.
      " 2133"
      "2344"
      " 123"
      "123"
      I need to remove the space
      could someone help me to write a function that loops through all tables and check cells if there are a space in the cell
      Thank you in advance
        • 1. Re: Remove space in cells.
          Chinnadk Level 4
          Try this,
          var doc = app.activeDocument,
            _tables = doc.stories.everyItem().tables.everyItem().getElements();
          app.findTextPreferences = app.changeTextPreferences = null;
          for(var i=0;i<_tables.length;i++)
                  app.findTextPreferences.findWhat = " ";
                  app.changeTextPreferences.changeTo="";
                  _tables[i].changeText();
          Regards,
          Chinna
          • 2. Re: Remove space in cells.
            Dapeamel Level 1
            Thank you Chinnadk
            works like a charm
            • 3. Re: Remove space in cells.
              Jump_Over Level 5
              ...don't you need spaces in headers, like "Totalsummary"?
              ...don't you use "spaced" format for numbers, like "1 232.56"?
              if no then yes.
              Jarek
              • 4. Re: Remove space in cells.
                Dapeamel Level 1
                this function is good,
                I guess I wasn't clear enough in the explaination tho..
                I gonna use grep instead,
                cause this function removes all spaces.
                so grep and a regex
                • 5. Re: Remove space in cells.
                  Teetan VK Level 1
                  Chinna
                  I suggest find grep instead of find text
                  app.findGrepPreferences = app.changeGrepPreferences = null;
                          app.findGrepPreferences.findWhat = "^ +";
                          app.changeGrepPreferences.changeTo="";
                          _tables[i].changeGrep();
                  so I think it will be a little better
                  VK
