This content has been marked as final.
Show 4 replies
1. Re: how to i resize a larger 72ppi image to better quality smaller image but for correct size to paste into flyer
sishamDSS Jul 28, 2014 6:47 AM (in response to Barbaloot)What PPI is the file you are trying to drag into?
Are you able to post your desktop showing both files..?
If you convert you 16cm/72ppi image to the 5cm/240ppi image and then save it. then check the ppi with the flyer. If the flyer is again large with a low res you'll get the cross over between them therefore the larger ppi image will appear large on the flyer document.
3. Re: how to i resize a larger 72ppi image to better quality smaller image but for correct size to paste into flyer
Barbaloot Jul 28, 2014 5:00 PM (in response to sishamDSS)Making a new background that was 230 dpi worked Thank you very much for both your replies
4. Re: how to i resize a larger 72ppi image to better quality smaller image but for correct size to paste into flyer
Barbaloot Jul 28, 2014 5:01 PM (in response to Barbaloot)I mean ppi
