2 Replies Latest reply on Jul 28, 2014 1:55 PM by HarveyLiu
    Can you fix my script problem?
    HarveyLiu Level 1
      Hi everyone
      I got this script:
      function: gen specify color of text to pdf
      everything was very well, unless final step, I want to the script keep the new file's name as same as my indesign file's name,
      and no need to type in (".pdf")
      Thank you all so much!
      Harvey
      var doc = app.properties.activeDocument && app.activeDocument;
      if (!doc) {alert("Adiós Amigo") ; exit();}
      var sN = doc.swatches.everyItem ().name,
          sID = doc.swatches.everyItem ().id,
          /** UI */
          w = new Window ('palette', "Print by Color"),
          g1 = w.add('group'),
          g2 = w.add('group'),
          st = g1.add('statictext', undefined, "Select Swatch from Drop Down List")
          d = g1.add('dropdownlist', undefined, sN),
          b1 = g2.add('button', undefined, "PDF"),
          b2 = g2.add('button', undefined, "Print");
          b1.onClick = function () {proccessPages (d.selection, true)}
          b2.onClick = function () {proccessPages (d.selection)}
      w.show();
      function proccessPages (s, e) {
          var l, c = 0, o, p, pO = {}, pA = [];
          if (s == null) {alert("No Swatch Selected") ; return;};
          app.findTextPreferences = app.changeTextPreferences = null;
          s = doc.swatches.itemByID (sID[s.index]);
          app.findTextPreferences.fillColor = s;
          var pageFinds = doc.findText ();
          if (!(l = pageFinds.length)) {alert("No finds") ; return;};
          for (c = 0; c < l; c++) {
              o = (p = pageFinds[c].parentTextFrames[0].properties.parentPage) && p.documentOffset + 1;
              if (p) pO["_" + o] = o; // if the finds on a page add to page list
          c = 0;
          for (o in pO) pA[c++] = pO[o];
          var pageRange = "+" + pA.join(", +");
          doc.printPreferences.pageRange = pageRange;
          if (!e) doc.print(true);
          else {
              app.pdfExportPreferences.pageRange = pageRange;
              f = File.saveDialog("Export PDF", "PDF: *.PDF");
              if (!f) return;
            app.activeDocument.exportFile (ExportFormat.PDF_TYPE, File(exportPath+'/'+linkname.name.replace(/(\.[^.]+)$/, '.pdf')), false, app.pdfExportPresets.item(exportPreset));
        • 1. Re: Can you fix my script problem?
          Jump_Over Level 5
          everything was very well, unless final step...
          Hi Harvey,
          Be honest, it can not work. There no exportPath, linkname and exportPreset in your code.
          You pasted it from a several independent codes and ask for help to fix it ==> but, to tell you the true, is nothing to fix.
          It reminds me very much one story happened to some guy somewhere:
          He was asked by a stranger:
          "Which way is shortest to another part of the city."
          The guy knew the city pretty well but explaining the way took a minutes.
          At the end, nonetheless, a stranger jumped to a guy's back and ask:
          "Could you kindly take me there, pls?"
          Jarek
          • 2. Re: Can you fix my script problem?
            HarveyLiu Level 1
            thank you Jarek
            for tell me the Truth
            Harvey
