I was trying to update but it didn't let me (Error at 50%, 70%, etc.). I have tried many times to uninstall and install again, it doesn't work. II've tried the link you provided but the solution didn't work for me (Error at 39% when downloading this time).
System Mac 10.8.5, Safari 6.1.3
Thanks so much, I'm going crazy!
Hello Rafel,
What is the error message that is displaying?
Please provide the Flash Player installer log file located at \Users\<YourUserID>\Library\Logs\FlashPlayerInstallManager.log. You can use the instructions at How to share a document to upload the file.
The user's Library folder may be hidden, if so, open Finder, in the Finder toolbar, click Go. Mouse-over the Go menu and click the alt/option key to display the Library folder. Click Library to open the Library folder. Navigate to the Logs folder and you should see the FlashPlayerInstallManager.log file.
Thank you.
Maria
Hi Maria,
thanks so much. Here's the link with the log and the screenshot. I had uninstalled Flash some days ago as it was recommended. This is what happens when I'm trying to install the v. 14.
Dateien freigegeben - Acrobat.com
Thanks a lot!
Hi Rafel,
Thank you for providing the screenshot and Flash Player install log file. Can you provide the Flash Player related content from the /private/var/log/install.log file?
Thank you in advance.
Maria
Hi Maria,
https://files.acrobat.com/a/preview/c57e9b94-ad07-404e-b6b8-80acea4d6b3f
Thanks so much,
Rafel
Hi Rafel,
Thank you for the file. Please do the following:
Another item to check is if the mach_kernel file (usually a hidden) file exists on your system. There are a few threads on here regarding the missing mach_kernel file. These two, keep getting "general installation error" message Mac OSX 10.8.5/Safari 6.0.5 and Re: Cannot install Flash player, contain good tutorials on how to determine if the file exists or not, and if not, how to restore the file.
Maria
Hi Maria,
the string is 10.8.5, and there is no file such as ServerVersion.plist.
I'll check the two tutorials you sent to check the mach_kernel file.
Thanks a lot, again! I hope I'll find the solution...
Rafel
