1. Re: PDF file has three parallel lines for each line object.
Larry G. Schneider Jul 28, 2014 9:21 AM (in response to CBTman)If you use the Direct Select tool (white arrow) to select one of the center lines what is reported in the Appearance panel?
2. Re: PDF file has three parallel lines for each line object.
Monika Gause Jul 28, 2014 9:22 AM (in response to CBTman)Depends on what the shapes you want to keep are. Closed or open paths? Any color differences or other differences?
3. Re: PDF file has three parallel lines for each line object.
CBTman Jul 28, 2014 9:26 AM (in response to Larry G. Schneider)It shows Stroke = Black, 0.01 pt; Fill = none; Opacity = Default.
4. Re: PDF file has three parallel lines for each line object.
CBTman Jul 28, 2014 9:29 AM (in response to Monika Gause)For the rectangles and circles, I would prefer closed paths.
For the letters and numbers, whatever makes it easier to simplify them.
5. Re: PDF file has three parallel lines for each line object.
Larry G. Schneider Jul 28, 2014 9:31 AM (in response to CBTman)And if you choose the outer line it will probably say Fill. As an experiment, try selecting one of the outer lines and then Select>Same>Fill Color and delete. You should be left with the strokes, Select All and change the Stroke to 0.5 or 1 pt. This what you want?
6. Re: PDF file has three parallel lines for each line object.
CBTman Jul 28, 2014 9:37 AM (in response to Larry G. Schneider)Larry,
That would have been the easiest way. Unfortunately, that is not the case.
If you look at the inserted figure, you would see that the half circle at the end of each triple line is a separate object. This means that all the lines, whether internal or external, are in fact individual strokes.
