2 Replies Latest reply on Jul 28, 2014 2:46 PM by myDavey
    Looping through objects - testing links
    myDavey Level 1
      Hi
      I have a script that moves all instances of a linked object according to user defined X,Y values.
      In order to do this, I need to loop through all objects with links
      What is the best way to do this?
      As of now, this is what I am doing:
      var g = myDoc.allGraphics;
      for (var i=0; i<g.length; i++) {
           if (g[i].itemLink.name == USER_LINK) {
                g[i].parent.move(undefined, [USER_X, USER_Y]);
      It works well, however I ran into some problems where link was null
      Also, is it always the graphic that is linked, or can its parent be linked as well?
      If not, then I can just condition that if itemLink == null - continue
      Any advice and guidance would be much appreciated
      David
        • 1. Re: Looping through objects - testing links
          Jump_Over Level 5
          if (g[i].itemLink && g[i].itemLink.name == "USER_LINK")     //     should be enough
          Graphic can be linked ==> itemLink !=null and itemLink.status can vary
          or pasted ==> itemLink == null.
          As far as I know graphic.parent can not be linked.
          However not every linked graphic.parent can be moved. I e. those one which are anchored with
          AnchorPosition.INLINE_POSITION and AnchorPosition.ABOVE_LINE
          Above case can be a source of error as well.
          Consider also locked object or locked entire layers.
          Jarek
          • 2. Re: Looping through objects - testing links
            myDavey Level 1
            Hi Jarek
            Thanks again!
            I forgot that in Javascript (and many others as well) the "and" statement works 1 piece at time
            Thanks for the information and help
            Regarding the locked objects/layers, I had taken care of that
            But not the anchored objects
            David
