• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Graybox at the instalation step - Windows 7 - Need help
Guest
Jul 28, 2014 Jul 28, 2014
Hi everybody,
I use Mozila Firefox, I can download it just fine, then I hit run, accept the security notification, and then here what I get every time :Adobe problem.JPG
I tried rebooting, didn't work.
Views
703
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Hello,
We have received a few reports of the window displaying without text, however, have been unable to reproduce it.  We would appreciate it if you could generate and submit a log file to aid in troubleshooting.  Can you please do the following:
  1. Download the installer and save it to the desktop
  2. launch the command prompt, click the Start orb and in the search field, type: cmd.exe
  3. When the command prompt utility launches, drag the installer from the desktop onto the command prompt window hit space key and type /debug
    • it should look similar to: C:\Users\UserID>C:\Users\UserID\Desktop\install_flashplayer14x32_mssd_aaa_aih.exe /debug
  4. Click Enter to proceed
  5. When the empty dialog window displays, go ahead and close it.
  6. A file named host.develop.log will be saved to the same location the installer was saved to (note, the online installer deletes itself once executed, so it will no longer be saved locally).
  7. Post the contents of the host.develop.log file here in your response, or share the file following the How to share a documentinstructions.
Thank you in advance.
Maria
Votes
Translate
Translate
Report
Report
Guest
Jul 29, 2014 Jul 29, 2014
I did step 1 to 4, but when I hit enter it says (location of the file) isn't recognized as an intern or extern command, an executable software or a command file.
Votes
Translate
Translate
Report
Report
New Here ,
I too have the same problem for this last while. I am running windows 7 and internet explorer 11.
I also tried the above steps like Extremisss and encountered the same issue.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hello,
Please make there there is a space between the file name and / and that there is no space between / and debug, as follows:
Maria
Votes
Translate
Translate
Report
Report
Guest
I installed it from firefox and it worked finaly. Thanks for the help anyways!
Votes
Translate
Translate
Report
Report
New Here ,
Jul 30, 2014 Jul 30, 2014
I am having same issue.  Performed diagnostic steps.  Here is output
Memory Initialized (Maximum)
Host Version: 3.5.4.25
"C:\Documents and Settings\XXXXXXXXXX\My Documents\install_flashplayer14x32_mssd_aaa_aih(1).exe"   /debug
System: Windows NT version 5.1.2600.196608
Added url to whitelist (localhost).
Added url to whitelist (solidstatenetworks.com).
Added url to whitelist (snxd.com).
Added read only registry path to whitelist (machine\Software\Microsoft\Internet Explorer\).
Added common name to whitelist (Solid State Networks I, LLC).
Added common name to whitelist (Adobe Systems Incorporated).
Extracting skin file (/app.config.xml)
Added url to whitelist (get.adobe.com).
Added url to whitelist (get2.adobe.com).
Added url to whitelist (aihdownload.adobe.com).
Added url to whitelist (airdownload.adobe.com).
Added url to whitelist (ardownload.adobe.com).
Added url to whitelist (download.macromedia.com).
Added url to whitelist (fpdownload.macromedia.com).
Added url to whitelist (fpdownload2.macromedia.com).
Added url to whitelist (fpdownload.adobe.com).
Added url to whitelist (fpdownload2.adobe.com).
Added url to whitelist (platformdl.adobe.com).
Added url to whitelist (platformdl-stage.corp.adobe.com).
Added url to whitelist (wwwimages.adobe.com).
Added url to whitelist (wwwimages.stage.adobe.com).
Added url to whitelist (dlmping.adobe.com).
Added url to whitelist (dlmping2.adobe.com).
Added url to whitelist (dlmping3.adobe.com).
Added url to whitelist (dlmping4.adobe.com).
Added url to whitelist (get3.adobe.com).
Added url to whitelist (get3.stage.adobe.com).
Added url to whitelist (adobetag.com).
Added url to whitelist (promotion.adobe.com).
Added read only registry path to whitelist (machine\SYSTEM\CurrentControlSet\Control\Session Manager\Environment\).
Added read only registry path to whitelist (machine\SOFTWARE\Microsoft\Windows NT\CurrentVersion\).
Added read only registry path to whitelist (machine\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\).
Added read only registry path to whitelist (machine\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\).
Added read only registry path to whitelist (user\SOFTWARE\Microsoft\Windows\Shell\Associations\UrlAssociations\).
Added read only registry path to whitelist (root\http\shell\open\command\).
Added read only registry path to whitelist (root\https\shell\open\command\).
Added read only registry path to whitelist (root\.htm\).
Added read only registry path to whitelist (root\.html\).
Added read only registry path to whitelist (root\IE.HTTP\shell\open\command\).
Added read only registry path to whitelist (root\FirefoxURL\shell\open\command\).
Added read only registry path to whitelist (root\SafariURL\shell\open\command\).
Added read only registry path to whitelist (root\ChromeHTML\shell\open\command\).
Added read only registry path to whitelist (machine\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\).
Added read only registry path to whitelist (machine\SOFTWARE\Macromedia\).
Added read only registry path to whitelist (user\SOFTWARE\Macromedia\).
Added read/write registry path to whitelist (machine\SOFTWARE\Adobe\Setup\Reader\).
Added read/write registry path to whitelist (machine\SOFTWARE\Wow6432Node\Adobe\Setup\Reader\).
Added common name to whitelist (Adobe Systems, Incorporated).
189 active MIME types
WebServer thread running
WebServer Listening on 127.0.0.1:2931
Browser cache flushed (0 removed) (713 checked) (0.05 seconds)
Browser: IE 8.0.6001.18702
Extracting skin file (mainwindow.config.xml)
Response code set [/mainwindow.html:200:0]
Response code set [/images/icon-blank.gif:200:0]
Response code set [/mainwindow.css:200:0]
Accept queue size of (2)
Response code set [/images/icon-complete-error.gif:200:0]
Response code set [/images/icon-complete.gif:200:0]
Response code set [/compact.min.js:200:0]
Response code set [/images/logo-adobe.gif:200:0]
Response code set [/images/bg-header-error.gif:200:0]
Response code set [/images/bg-close-program.png:200:0]
Response code set [/images/bg-download-bar-full.png:200:0]
Response code set [/images/bg-download-bar-empty.png:200:0]
Response code set [/images/button-center.png:200:0]
Discovering default browser...
Default browser: "C:\Program Files\Mozilla Firefox\firefox.exe" -osint -url "%1"
Skin version: 2.0.2.7
Document ready triggered
Extracting skin file (locale/en-us.json)
Unable to extract skin file (locale/us.json)
Unable to extract skin file (locale/en.json)
Response code set [/images/button-right.png:200:0]
Response code set [/images/button-left.png:200:0]
Extracting skin file (workflow.json)
Extracting skin file (interop/downloader.dll)
Loading interop library (C:\Documents and Settings\XXXXX\Local Settings\Application Data\Adobe\downloader.dll) (3.5.4.25)
Downloader Version: 3.5.4.25
Solid Core v0.82 () in use (S11)
Cwd [00:11:11:B6:27:1A]
Torrent Agent: -SC0082-
Torrent Agent: -SD354P-
Starting manager thread
Manager state changing from (Idle) to (Start)
Manager state changing from (Start) to (Process)
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Jul 31, 2014 Jul 31, 2014
Thank you for providing the log file.  We are reviewing the log file.
Maria
Votes
Translate
Translate
Report
Report
LEGEND ,
Aug 01, 2014 Aug 01, 2014
LATEST
In order for you to get the installation done, use these installers:
Votes
Translate
Translate
Report
Report
